Thread: Is there a list of questions to ask potential builders?
    Jul 2016
    Flower Mound, Texas
    6
    Wondering what the key questions I should ask regarding the pool construction.....not about business practices, but the engineering and build of the pool & equipment. Any help?
    Pool Information: In the process of finding a builder.
    Jun 2016
    Martinez, CA
    207
    Re: Is there a list of questions to ask potential builders?
    Biggest issue for me was how they clear mechanics liens. In california, if you pay the builder but the builder doesnt pay the subs, you are still liable. Ultimately asking builder to,furnish the mechanic lien releases at each payment schedule will help protect you.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    jdoty1977's Avatar
    May 2016
    Little Elm TX
    38
    Ask about rebar (prefer #4 in Texas), structural warranty (lifetime transferable in case you sale your home). If they stand behind a solid structure you can be fairly confident. Equipment is really all up to you but make sure there are 2 drains and plenty of returns for good water circulation. Lastly, plaster, pebble, quartz, etc. Look into your finish and desired water color. Then look again and again. The builder may even have pools you can go look at. Finish/Plaster is probably the single most important thing to obsess over.
    2016 Build: 20x30 15K Gal-IG Gunite, #4 Steel Tanning Ledge, Bubbler, Flagstone Coping, Stamped Concrete Deck, Jump Rock, Rock Waterfall, CLI Majestic Isle Pebble Finish, 3 Multi-Color LED lights, Ozone-DEL Eclipse 10, Empty Inline Tab Feeder, 2 HP Jandy Pro Series ePump with SVRS, 2 Skimmers, 6 Returns, 2 drains, 1 Cleaner Return, Jandy CV Filter 460 SF, Dolphin Nautilus+, iAqualink RS Automation, Borates, Test Kit Taylor k2006
    Apr 2013
    Sacramento, CA
    2,769
    In the market today if you have to worry about liens then you chose the wrong builder.
    How many pools per year do they do. Small guys with subs should be doing at least 20 , 30 to 50 is better. Integrated builders at lest 200. 300 to 400 is better.
    Get the name and phone number of five or ten references.
    Are they a integrated builder or do they use subs. If they use subs how long have the subs worked for them.
    How long have they been in business?
    Will they get the pool engineered? Some Texas jurisdictions require engineering, others don't.
    Make sure the payment schedule is back loaded. If you have to pay anything up it should be small. At least 10% should be payable five days after final inspection and completion of the punch list.
    What brand equipment do they use. What automation system?
    What is the warranty on the pool shell and finish. Do they add to the manufacturers 3 year warranty on the equipment.
    How much extra are the specialty finishes?
    That's a start.
    Always get bids from at least two builders, three bids is better. Try to get them to bid on roughly the same thing. I paid for a conceptual drawing and got bids off of that. Pool builders want to have use their design and choices so it is difficult to compare bids.
