Thread: LED Lighting
    LED Lighting
    I have a sun shelf where one of the lights has burnt out. Is this something I can replace, or does the pool need to be drained enough so I can access the light?
    Thanks in advance
    George
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: LED Lighting
    you should be able to replace it, do you know what type it is? can you get a close up picture of it and post it, maybe someone will know what it s
    Re: LED Lighting
    I will do so today
    Thanks
