Results 1 to 8 of 8
Thread: Can I patch a 4' gash in my Intex pool?
    Jul 2016
    Cleburne/Texas
    1
    Split from ughhh... dog bit my liner. Zea3
    is it feasible that this patch and repair glue will work on a 4 foot slash in wall of AGP fiber reinforced wall?
    Debbipool
    Above Ground Intex A 18x48 F G01 13 RO
    Ultra Frame
    Texas
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    Re: Can I patch a 4' gash in my Intex pool?
    No harm in trying. You should know right away if it is going to stick. I would do one small one over the slash followed up by another bigger one over it.
    Good luck and let us know what happens.
    Kim
    ta2dwonderwoman's Avatar
    Jul 2016
    fall river ks
    499
    I have heard good things about JB water weld , 6 bucks at home depot...classic jb weld is amazing so wonder how this item would work?
    Windy ☆ 22ft round, 11,400 gal, intex ag vinyl, SF70110-1 Intex sand filter/2800 gph pump, CS8110 intex swg, city water, solar heater, TF100 test kit/speed stirrer, over the wall intex skimmer~fall river ks~SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math
    Jul 2012
    Tallahassee, FL
    30,559
    Quote Originally Posted by ta2dwonderwoman View Post
    JB weld Water IS awesome stuff BUT is not good for a pool liner application due to not being able to get it flat enough to keep it safe from people knocking against it.
    The vinyl repair kit is THE chose to fix this.
    Kim
    Casey's Avatar
    SW PA
    10,450
    A 4ft slash?! 4 ft?!
    Absolutely not. No. I'd never even attempt this.
    Jun 2014
    Uxbridge Ontario
    56
    4 feet in the WALL?
    Absolutely no way!
    There is no way it will hold.. ever!
    21' x 52" Round Above Ground. (Buried 2') AquaPro 1HP pump, Jacuzzi 19" Sand filter, Hayward inline chlorinator.
    Hayward H200 millivolt NG Heater, SunQuest 2 x 2'x10' Solar heater.
    May 2012
    Findlay Ohio Area
    6
    You would need a some large vinyl patch or find someone who is getting rid of their old Intex due to a similar problem. Get HH-66 vinyl cement. Get at least the 18oz size. This stuff works. I had to do this on mine and it held very well. You will need to patch BOTH sides. Corners of the patch need to be rounded (I didn't do this). The one thing I wished I had done is cut out the gash so its a clean hole as the vinyl in the middle of the gash wants to curl. Mine tore due to not draining the pool below the filter ports. Another thing is to make sure your the area is clean around the area. Also Take your time, don't allow ANY air bubbles. I didn't so I've got leaks, BUT it's holding, quite well. I have leaks, again due to my impatience. I had access to an old Intex liner I hadn't disposed of yet that allowed me to patch.
    You can see in the picture below where I patched.
    Coleman (Intex Clone) 16 Ft Diameter x 4 (more like 3.2 feet), 4800 Gallons. Intex Sand Filter and Pump (2600GPH). Hard Plumbed. Heyward Skimmer and Return.
    Casey's Avatar
    SW PA
    10,450
    I would advise to NOT do this.
