Results 1 to 8 of 8
Thread: What's eating my chlorine?
    Mar 2016
    walker/mi
    28
    I've noticed recently that more and more chlorine was needed to maintain FC. The water has been crystal clear since I filled it about a month ago. Chemistry has been right on other than allowing FC to drop below the minimum a couple of times. CC has never registered more than .5, and that's only been in the last several days.
    So yesterday I decided to SLAM in order to get ahead of whatever might be in there. I accidentally brought FC to 25 (forgot to change values in poolmath). Anyway, last night it was 25, this morning it was 20, and now it's 15. Is this normal for water that's always been clear and never shown visible signs of algae?
    FC 15
    CC 0.5
    TA 150
    CH 275
    PH 7.6 (before slam)
    CYA 40
    26K painted gunite / 24" Cristal-flo (prefilter) to Dayton 4VMN8 cartridge filter / 1.5 hp Pentair Superflo VS pump / Maytronics Dolphin S200 / TF-100
    JoyfulNoise's Avatar
    May 2015
    13,227
    Re: What's eating my chlorine?
    Quote Originally Posted by johnly View Post
    FC 15
    CC 5.5
    TA 150
    CH 275
    CYA 40
    I'd repeat the OCLT again but if your FC loss is that high, you've got something in your water. Remember, here at TFP we have a saying -
    CLEAR water is NOT a sign of CLEAN water!
    or, to put is more succinctly,
    Clear does not equal clean!
    You likely need to SLAM.
    Matt
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    There are two things that lower chlorine, sunlight and algae/bacteria. If it dropped 5 ppm over night you have something.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,499
    Yep, I had to SLAM last summer with crystal clear water and no CC. I had some algae growing in patches in the rocks/grout under the waterfall, some in the pool cleaner and some junk behind the light. I was also lazy about brushing last summer. Now I try to brush every week or two for sure.
    Mar 2016
    walker/mi
    28
    Thanks for the replies. Yeah, this is one lesson I will learn only once. I just dislike brushing. Do suction side cleaners eliminate the need for brushing? If not, that's fine. I also dislike folding laundry, but I do it anyway.
    domct203's Avatar
    Jun 2015
    CT
    3,592
    FC 15
    CC 5.5
    TA 150
    CH 275
    CYA 40
    Have you been using non-chlorine shock (MPS)?
    That CC 5.5ppm is showing that your chlorine is working hard to oxidize something .....
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mar 2016
    walker/mi
    28
    Oops, that CC should have been 0.5. And no, I've not used any pool "products" - following TFP to the letter. Very grateful to this site and it's contributors.
    This morning's FC is 16, same as it was last night. I win!
    DFW, TX
    24,499
    Nice! Good answer!
