Results 1 to 13 of 13
Thread: Can't remove pump lid
    May 2013
    Bensalem, PA
    13
    At times I've always had some trouble getting my pump lid off to clear out my strainer basket, but I could eventually get it off after using some more elbow grease.
    But after lubing the 'O' ring last week, I can't get the lid off now. For 3 days I've tried to the point where I've strained a muscle in my forearm.
    Anyone have any suggestions before i take a sledgehammer to this pump and smash it out of spite?
    Jul 2015
    Central Valley CA
    1,107
    Re: Can't remove pump lid
    Could be suction holding it, on try opening the pressure gauge on your filter and wait till the air sucking sound goes away then try the pump lid.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2013
    Bensalem, PA
    13
    Quote Originally Posted by atttech-2 View Post
    No air sucking sound occurs when i open the pressure gauge, water just drips down.
    30,413
    Tap it gently with a large rubber mallet. What did you use to lube the 0-ring.
    May 2013
    Bensalem, PA
    13
    Leslie's pool & spa lube.
    May 2013
    Bensalem, PA
    13
    Tapped all around the lid with a mallet, still won't budge...
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    I've been using a strap wrench on mine. they are very cheap.
    May 2013
    Bensalem, PA
    13
    Quote Originally Posted by mulia View Post
    I will pick one up tomorrow and give it a try, thanks!
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    I ended up using a large clamp with rubber grips. Learned my lesson on how tight it needs to be. Rest that arm, Its a long summer!
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    Can you post a picture?
    Also, don’t use Teflon based lube, it’s no good. Only use Silicone based lube (Boss 820, Jack’s 327 or magic lube II red label).
    Support the site
    May 2013
    Bensalem, PA
    13
    Quote Originally Posted by rbinn View Post
    I'm definitely resting the arm for the night, I'm getting frustrated after each attempt.
    Never had this much trouble in the 3 years I've had this pump. I guess I shouldnt have lubed the 'O' ring because that's what I did last time I opened it.
    May 2013
    Bensalem, PA
    13
    Quote Originally Posted by JamesW View Post
    I will definitely get some silicone based lube for next time, here are some pics....
    Use the rubber hammer to tap the lid handles counterclockwise.
    Support the site
