Results 1 to 14 of 14
Thread: skimmer sock
    delfargo's Avatar
    May 2008
    some cornfield in central illinois
    86
    skimmer sock
    i've heard mention on several forums here about the "skimmer sock" to help filter out the really fine stuff. is that something a guy could make out of a coat hanger & some panty-hose or something like that, or is it more "involved" than that? i've never seen one before. can anyone fill me in? thanx.
    30' round above ground - 21000 gal. (shade ONLY in the evening),
    pentair dynamo 1.5 hp pump,
    pentair sand dollar 150 lb.sand filter,
    bbb method.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: skimmer sock
    Just the pantyhose should work, cut off one leg (or buy knee highs ) and stretch it over the skimmer basket.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: skimmer sock
    Here's a couple of pictures of what a dirty one looks like, so you can see how it stretches over the skimmer basket, and so you can see what kind of **** it catches.
    BTW, I buy mine at WallyWorld.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    delfargo's Avatar
    May 2008
    86
    Re: skimmer sock
    so it would go over the actual basket, eh? for some reason i was imagining it stretched over some kind of frame in front of the skimmer (pool side). and the reason for this "sock" is to catch the finer particles that a sand filter might not get? seems like you'd need to check and empty quite often.
    o.k. then...i'll give it a try. thanx for the info.
    bbb method.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: skimmer sock
    It goes inside the basket and is stretched over the rim. I put a rock inside mine to keep it from floating up once the pump shuts off. This keps it submerged inside the skimmer basket instead of floating up and spitting all that crud back into the water.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Mar 2007
    Richmond, Va
    179
    Re: skimmer sock
    I;m probably missing something here as usual, but how is it that the skimmer sock does not get sucked down through the basket and end up in the filter?
    18 ft.52" Round Atrium AG -7600 gallons, Sand Filter, Vinyl liner, Royal Entrance Steps, 80 lbs.solarsalt
    May 2008
    Virginia Beach, VA
    84
    Re: skimmer sock
    The skimmer sock doesn't get sucked through the basket because it's porous enough to let all the water through, but will trap small leaf and dirt particles that would otherwise fit through the strainer holes.
    28K IG Vinyl lined pool - 1 skimmer, 2 returns
    Hayward DE 60sqft filter; Polaris 280 vacuum with booster pump
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: skimmer sock
    I have had a case or two where the sock would catch enough **** to where parts of it would start getting sucked through the basket. I'd have all of these little balls of cloth that I'd have to pull back through from the inside. Oh, and then there was the Great Borax Incident of '07, where I dumped too much borax too quickly into the skimmer which clogged up the sock, pulled the basket against the bottom of the skimmer, and broke the basket. I cursed mightily at my stupidity for that one.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: skimmer sock
    You do have to watch them because if they get overloaded, they can restrict flow into the pump - but they do a nice job of catching that **** that gets through the basket and either ends up in the pump pot basket or further filling up the filter itself - tree pollen time and itty bitty gnats are the big reason for me to use these. I wouldn't go without them anymore.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Feb 2008
    Charlotte NC
    44
    Re: skimmer sock
    Here in NC, these are invaluable during pollen season. I tend not to use them later in the summer, and just backwash somewhat more frequently.
    22,000 gal, IG vinyl, 3/4 hp pump, 300lb sand filter (switched from DE), converted from baquacil (thanks to Ben), BBB since 2004
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    352
    Re: skimmer sock
    I wished I'd had one yesterday when an ant swarm decided to go for a swim in our pool. I backwashed ants for a while...suspect that will be an ongoing thing for a while. My much better half was out of town...I certainly wasn't going to go plundering through her things and grab the wrong knee-highs!
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Feb 2009
    352
    Re: skimmer sock
    WELL! The ants came back! Another swarm. Never had one before, much less two in the same week! This time I was able to secure a knee-high...and caught the critters without overloading the filter. Wonderful idea!!!
    dsilchenstedt's Avatar
    May 2015
    Rockport tx
    62
    Re: skimmer sock
    2009 and still helpful!!! Knowledge never gets outdated
    Bringing it back from the abyss, bwahahaha.
    Round Frame Pool 15' x 42" (app. 3800 gallons) converted to Krystal Clear 2800 GPH .75 HP (conversion thread Here all the links/info you will need are within), TF100 Test Kit with speed stirrer. My first SLAM
    Jun 2014
    14,961
    Re: skimmer sock
    Absolutely. Thank goodness for the "Search" feature on this site.
