Thread: Concern about a little accident with reagent R-0013
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Hello everyone and Happy Fourth of July!
    I, by mistake, added to the pool water about 1 or 2 oz, maybe 3? of reagent R-0013.
    Do I need to worry about it or it is not a big issue since the amount was just a little?
    Is it safe to use the pool?
    My pool is 15k gallons.
    Thank you in advance!
    15K gallons, Plaster, Taylor K-2006C & TF-100, DE, non SWG, Hayward TriStar VS variable pump
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Concern about a little accident with reagent R-0013
    No concern to me, but don't do it again... 😊
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8,400 gal, with salt and borax, INTEX 3,000 GPH pump with 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Feb 2015
    Chandler AZ
    938
    3oz in 15,000 gallons should have little effect. Here the MSDS: http://www.taylortechnologies.com/MSDSS/0013.PDF
    While the MSDS does say it can cause irritation, remember that's undiluted. In a 15k gallon pool you have effectively diluted 3oz of R-0013 80,000 (80k) times.
    How are your test results? How's the water look? If your test results are within TFP recommended guidelines, it's safe to swim.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    A few ounces should not pose any risk.
    Support the site
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Quote Originally Posted by proavia View Post
    Test results are all good. The water is clear. Thank you your reply.
    trevorfl's Avatar
    Jun 2015
    Orlando, FL
    45
    Quote Originally Posted by JamesW View Post
    Thanks!
