Thread: Re: Could someone post pictures of the inside of Zodiac PLC1400 - odd request I know
    I too have the same salt cell. It seems that the piece inside under the middle pin has broken off. Can it function without this piece? I also hear a rattling inside the generator when I shake it. I had code for bad flow sensor and replaced that. A day later got the 194/125 code.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP
    You may need to call Zodiac to see if they know that code
