Thread: Safe to swim?
    Safe to swim?
    Added bleach last night to pool to try to kill some algae on tanning ledge.
    Tested pool and have an fc of 14.5, cc 2.5, cya coming up 0... So I need to increase that.
    My question is... Is t safe to swim with the fc of 14.5?
    15k freeform shotcrete sport pool 3.5-5-4, hayward swimclear c4030, 1.5hp hayward Northstar pump, polaris 280 with hayward booster, hayward turbo cell swg
    Donldson's Avatar
    NW Ohio
    2,893
    Re: Safe to swim?
    If your CYA is zero then no, that is far too high to swim with no CYA to buffer it.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2015
    Central Valley CA
    1,107
    Re: Safe to swim?
    If CYA is 0 than no don't swim
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Safe to swim?
    It is safe to swim when
    FC is above minimum and up to shock level for your CYA, FC/CYA Chart
    PH is 7.2 to 7.8
    Water is clear
