Results 1 to 10 of 10
Thread: Another needed upgrade and why (pic)
    May 2008
    southern New Hampshire
    41
    Ever have one of those cheap, cheesball flex-hoses rupture? Of course, mine ruptured, and emptied my pool right down to the skimmer lower level while I was at work !!!!!
    Well, not going to happen again! I'm hard plumbed now!
    "To be old and wise, you must have been young and stupid"
    18X33 Aquasphere buttress AG pool
    Pentair SD60 sand filter/1 hp pump/ Pool Frog
    Polaris 65 super turtle
    Ohio
    87
    Re: Another needed upgrade and why (pic)
    I just completed doing the same thing as I wanted to get rid of my flex hoses as I feared they would burst sometime. It is amazing how much more flow I get with the PVC hard piping and I did understand the friction loss from my firefighting days but it is even more than I expected.
    How ever I did have one glued joint blow apart for some unknown reason both parts looked good as well did the glue application. Everything was covered on both pieces. I just reglued another section of pipe back into the Jandy valve and all is working now. If it matters I used the Purple Primer and Clear glue on all fittings.
    Dennis
    24'x54" Sharkline Matrix by Wilbar International, 15,200 gallons (2015)
    Jacuzzi 75 sq ft Cartridge Filter 1 hp two speed pump
    Solar Heat with Goldline GL-235 Controller
    Intex Krystal Clear Model 28669 SWG
    TF100, SampleSizer, and Speed Stir
    Mar 2009
    NJ
    215
    Nice! I love seeing pics.
    I'm hard plumbing my 18' AG pool from the get go. I've heard the horror stories and the benefits of doing it, so I figured why not. The horror stories don't scare me, it's really just for the efficiency of it all. Thanks for sharing.
    It's also nice to see people doing the same thing as me with somewhat similar sized pools. Yes, mine is smaller. Darn-it!!! lol. I've got an 8000g with 200 sf cartridge filter and 1.5hp 2 speed pump. 2" pvc though. My low speed will surely do the job with this setup. I think it uses 2.8 amps @ 120 volts on low. Not bad.
    Good luck and thanks for the pics!
    18' x 54" Round AG 7500 gallon w/small prefab 2-piece fandeck
    Waterways 200sf Cartridge Filter, 1.5 hp 2-speed pump. 2" pvc piping
    Pool Pilot Total Control swg w/acid tank feeder
    Pool Rover Jr., BBB, TF 100 test kit
    May 2008
    41
    Quote Originally Posted by Lazyman
    My hose burst right at the hose clamped return fitting in the wall. This is where I had the most vibration which actually looked like it was stressing the wall fitting. When you hard plumb, all the vibrations will be gone as well which will lessen the likelyhood of stress cracks in the skimmer assemble, and return bung fitting. I am also glad that my pump stayed "wet" and didn't burn out!!
    I only have one concern about switching to hard plumbing.
    How easy is it to change your filter sand with the hard plumbing attached?
    Also, can you buy everything you need at Home Depot? If so, I might do this in a couple of days.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    Great Job ...the only thing you want to look out for though is that the 90deg elbows you used are not sch 40...they are dwv and not rated for pressure fitting...they may very well hold up as I have made that mistake in the past, but as the previous poster mentioned...this is probably why they experienced the blowout, even though they felt the fitting was properly glued.
    Jun 2007
    Poughquag, NY
    217
    Good point on the Sch 40. My brother in law just put up an AG with a main drain (I tried to talk him out of it) and he used Sch 40 pipe but didn't think about the fittings. When I pointed out that the fittings he was using for the pump/filter were not Sch 40, he just about had a fit. Too late to worry as the pool is up and filled.
    Home Depot does not carry much Sch 40 fittings any more, Lowes does. Almost any fitting that has a "collar" (where the ends are larger than the main part of the pipe) is not going to be Sch 40.
    On another point, I would support the long horizontal runs somehow. If someone were to accidentally step on those long runs, you could have a serious break or possibly bend the pool wall. If they were supported by bricks or something, much less chance of serious damage.
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
    May 2008
    41
    Quote Originally Posted by riverwalker76
    If you look in the pic you will see 2 flanged unions on each pipe assembly. These unions quickly and easily unscrew by hand, and then you can remove the pipes to do filter maintenence.
    I can shut off the ball valve at the skimmer, shut off the ball valve in the return line, or I can install my winter plug directly into the return bung fitting. It works awesome!
    Feb 2008
    Milford, CT
    333
    For the sake of preventing vibrations breaking your jet and skimmer connections, I think Id put a Fernco (rubber coupling) fitting somewhere in each line.
    Other than that, nice job! Its amazing how good PVC work can make a pool look nicer
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Hi,
    What is the fitting on the skimmer line, just below the shut off, above the elbow?
    John
    16500 IGP Vinyl liner Oval Shaped
    3/4 horse Hayward Pump
    200lb Sand filter
    "Community Pool Idiot"
