Hi, please forgive my ignorance on pools but this is my first attempt at putting up a pool and so far not so good. I have an Intex 10x30 above ground pool, that has a filter pump with 3 hoses, 2 out and 1 in. I filled the pool with water and added the proper chemicals. I ran the filter pump for about 10 hours yesterday and everything seemed ok. This morning however the pool lost a lot of water. In inspecting around the pool there is no obvious leak. In fact I can't find where it is leaking at all. The only guess I have is an issue with the filtering system. The reason I believe that is because I actually filled the pool on Saturday and Sunday morning it was fine. It didn't leak until last night and yesterday I ran the pump for a long time. It looks like the water is right at the line of the outbound hoses. They appear tight but I did notice yesterday that I was getting a lot of air trapped in the hoses. In fact one of the things it says to do is to unscrew the top of the filter and wait for the water to flow out, but it never did. Water was circulating into the pool through the input hose however. I shake each hose and the air bubbles appear to move, but it doesn't change anything. I am also noticing a white sediment at the bottom of the pool. So I guess my questions are, how can I tell whether or not the hoses and pump are working properly and why the chemicals are still visible in the pool? Thanks for any help.
