Results 1 to 11 of 11
Thread: Putting rocks around Above ground pool
    Cool Putting rocks around Above ground pool
    Hi there!
    Brand new pool owner of a 24 foot round above ground pool. The pool company that installed our pool suggested putting down plastic around the pool and securing it with tape before we put our rock down. What kind of plastic do we use as well as what kind of tape? I tried calling back the pool company but I received two different answers so any help would be appreciated, as one person told me to leave the Tape on to keep the pool wall sealed from water spilling over the sides, and one person told me to take the tape off as it was just there to hold the plastic in place. I have also read that rubber roofing flashing also works well to form a barrier against the rocks penetrating the pool? Any help would be greatly appreciated!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Putting rocks around Above ground pool
    I never met a rock yet that wouldn't hold down some landscape fabric. I have no idea why you would "tape" anything.
    I think they said to use the tape to form a seal so water doesn't get through. They were clear in saying not to use landscaping fabric and to use plastic but I'm not sure why.
    Apr 2010
    East Texas
    9,659
    I bet they're not either!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    If you are putting regular, chipped marble or river pebbles around your pool as most people do, these small stones are not going to penetrate the walls of the pool. If they were, a little plastic certainly wouldn't stop them from puncturing a steel wall! The whole point of adding the stone is to promote drainage so water doesn't collect at the bottom rails from rain or splashout. If you add plastic, you will be holding water in place. If no water gets behind it then its fine, but if water does get behind the plastic then it has no where to go and the ground will stay damp.
    I don't have any plastic under my brick around my pool. I used brick since I had it on hand, and I haven't had any problems with water build up.
    Love TFP? Become a
    TFP Supporter!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    I put a tarp under my rock the first year, but since it was waterproof, rain and splashout pooled up in the rocks and got nasty. I ended up poking holes in it to let the water drain.
    The next year I took it up and replaced it with water.permeable landscaping liner. It has worked perfectly.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Thanks everyone! Very helpful! But another quick question....do we cover the copper wire that extends from the pool up right to the filter with the rock, as I'm afraid someone is going to trip on it. I stepped on it lately just a few moments ago I hope it didn't do any harm!
    May 2014
    Clinton,Iowa
    42
    Copper wire as in electrical wire?
    28' Above Ground Pool, 20,000 Gallons
    Sand Filter"
    Model #AC16985
    Pool built in July 2012
    Clinton, Iowa
    I believe It grounds the pool
    Jul 2016
    Montreal
    2
    I agree,Better not to use plastic because if the water does not move out then the ground may remain damp.
    May 2012
    Montville NJ
    545
    Quote Originally Posted by poolfamily5 View Post
    Thats your bond wire. As long as your inspector has seen it, you can cover it with rock. You are not going to damage it.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
