Thread: dumb question
    May 2016
    spring hill fl
    13
    dumb question
    My chlorine levels are off the charts because I slammed the pool and was wondering how to check the chlorine since it is reading above 10? My water is cloudy atm but I think I am on the right track now due to gray sand looking debris at the bottom of my pool that I vacuumed out yesterday. I never got that before so I think I slammed it correctly this time. I also bought a proper test kit! Taylor Technologies K-2005 - DPD Complete Chlorine Kit that I can test for everything.
    Total Noob!
    Spring Hill, FL.
    5455 gal AG Vinyl pool
    635t Intex filter (cartridge)
    Krystal Clear 7110 SWG
    Jun 2014
    15,212
    Re: dumb question
    Unfortunately, the K-2005 doesn't have what you need to test FC over 10. You need the FAS-DPD portion as seen HERE. By adding the FAS-DPD to your current K-2005, you essentially turn that kit into a K-2006 which is one of the TFP recommended test kits.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: dumb question
    Also, don't forget that SLaMming is not a one time thing. The M is for maintain. Once you get the FC to the proper level for your CYA, you need to test and redose as needed to keep it up there. You keep doing that until you pass the 3 tests.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2016
    spring hill fl
    13
    Re: dumb question
    okay but isn't there a way to dilute and multiply? I guess that is what I should have asked
    Total Noob!
    Spring Hill, FL.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: dumb question
    It would not be very accurate.
    30,431
    Re: dumb question
    mdsmitty,
    What you are doing is tossing chlorine in the pool but you are not SLAMming. Your algae will come right back.
    Your K-2005 kit needs the FAS/DPD chlorine test purchased seperately and then you will be able to SLAM properly. You can not do it with your current kit.
