Results 1 to 11 of 11
Thread: pump running but does not pump water back in to pool
    Jun 2016
    Israel
    23
    My pump is not moving water. The water will fill up the pump. But it does not pump it back into the pool
    SummerEscape Vinyl round. 366x122m
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,264
    Re: pump running but does not pump water back in to pool
    Has it been working fine and just stopped working, or is this a new setup?
    Have you done anything recently with your filter?
    Could you take a couple of pictures of your equipment and attach them?
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2016
    Israel
    23
    This is the first time i have run it.
    Jun 2016
    Israel
    23
    View Picture (1632 x 1224 pixels) @PicResize.com
    I have removed skimmer hose from pump, as it fills pump up with water . When I did try the pump that hose was attached.
    With a small tiny leak.
    needsajet's Avatar
    Jan 2016
    4,264
    so can you hear the pump running when you switch it on?
    and when you took the pipe off the bottom of the filter pump, did water come out of it, as in draining some of the pool water?
    Jun 2016
    Israel
    23
    Quote Originally Posted by needsajet View Post
    yes it came gushing out.
    i can hear it making sounds
    needsajet's Avatar
    Jan 2016
    4,264
    try the pump with the return pipe disconnected, see if water gushes out
    Jun 2016
    Israel
    23
    Yes. When i remove the return pipe water comes out of both return pipe, and also from the return side of the pump.
    I will also notice that water leaks from the pump, not alot but the clamps that comes with plastic are horrible.
    needsajet's Avatar
    Jan 2016
    4,264
    OK, take the pipe on the return side off the pump. Water will come out of the pump, but just from the pool draining, through the pump. Quickly turn the pump on and see if the flow increases. That will explain whether or not the pump is pushing water.
    Jun 2016
    Israel
    23
    Thank you. Pump now pumping when runniny
    needsajet's Avatar
    Jan 2016
    4,264
    Excellent!!! Shalom
