Results 1 to 8 of 8
Thread: ughhh... dog bit my liner.
    Jun 2015
    Waycross, Ga
    36
    Well, brand new 26 x 52 Intex. After working several weeks nonstop on a less than ideal location- fighting roots, moving dirt, leveling, tamping, digging in pavers, cutting and putting down foam insulation... I go get my liner from the garage and discover the dog chewed on an exposed corner and put punctures through it in about 3 layers where it was folded up. OMG I am just about fit to be tied. Now I'm reading about patches and trying to find all the holes. I'd laugh if this pool wasnt about to whip me as it is.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    Re: ughhh... dog bit my liner.
    Welcome to TFP!
    Dang dog!
    kk_isme's Avatar
    Aug 2015
    North Central Texas
    108
    Oh, dear. I have a big dog that has chewed up so many things, I could just beat him. You have my sympathies.
    14,000 gallon above ground 24ftx56in round vinyl overlap liner steel wall sand filter 1/2 hp pump heavy lime in city water morning shade
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    Amazon.com : Boxer Adhesives No.110 Vinyl Pool Repair Kit : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    You might be able to patch all of the holes????? The above is the best patch stuff out there.
    Bad doggy!
    Kim
    Jun 2015
    Waycross, Ga
    36
    Going to try to find & patch them all. A new liner is $400. One set of tooth holes is right on the bottom seam area. This is like a bad dream.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    It could be worse, I thought your title said "ughhh... dog bit my liver."
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Jul 2012
    Tallahassee, FL
    30,510
    Okay so here is the patching 101.........cover the hole with just bigger than the hole THEN cover again with another patch bigger again. Cut the patch in a circle aka rounded edges only. That helps it stay on.
    Good luck
    Kim (GLOCK??? LIVER! OUCH!)
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Quote Originally Posted by kimkats View Post
    Good luck
    lol I know, right? Interesting about the patch method. I did not know that double patch method. Good info.
