Results 1 to 7 of 7
Thread: Pentair IC40 SWG average output/runtime
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    I have a Pentair IC40 SWG. My pool is 22000 gallons, cya level is 80, single speed pump runs 8 hours a day mostly during the time the sun is on the pool. Pool water temps have been 74-78. Ambient has been around 85 degrees. Water is balanced and all levels are good. Passes OCLT. No CC AND CRYTSAL CLEAR.
    My question is what percent output have people been setting the SWG to with a similar setup to maintain 6-7 FC?
    22,000 gal Cardinal Oasis 36x18 IG Vinyl
    Pentair IC40 SWG Sand Filter 1 1/2Hp Superflo pump Single Speed 3450 RPM
    Build date 9/25/15
    Taylor K-2006 with Salinity
    City water for fill
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pentair IC40 SWG average output/runtime
    while not the IC40, mine is the curcupool SJ-45.. I run 12 hours a day at 75% and have 7 FC
    pool 85/90 degrees
    13000 gal
    80 CYA
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    Quote Originally Posted by cowboycasey View Post
    pool 85/90 degrees
    13000 gal
    80 CYA
    Thanks for reply
    Build date 9/25/15
    City water for fill
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,245
    Mine has about 95% of the output of the IC40, and in the heat of summer, I run it 11 hours at 50% (12,000 gallon pool) and that is replacing a bit over 3 ppm FC per day.
    To replace a typical loss averaging 2.5 ppm per day in a 22,000 gallon pool, the IC40 needs to run about 8 hours at 100%, or for example 11 hours at 70%, or 16 hours at 50% - whichever suits your filtration run time.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2015
    Orange County, CA
    144
    Every pool is different so you need to experiment. You'll have to just pick a percentage and then check everyday and adjust the percentage and/or hours the SWG is running as needed to provide the FC you need. There is no one size fits all for SWG adjustment.
    17k IG plaster pool+ spa, Stonescape mini-pebble midnight blue, marble coping, Trex and porcelain tile decking, Pentair Intelliflo VSP x 3 (filter, laminars and spa jets), Pentair IC40, Pentair MasterTemp 400, Pentair Quad DE 100, Pentair CC 150 for laminars, Intellibrite 5G LEDs, MagicStream Laminars x 3, Intellitouch i9+3 automation with Screenlogic2, IntellipH, Dolphin s300i, TFTest kit, SpeedStir
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    Quote Originally Posted by Ocgasman View Post
    Yea I get that.. Just curious what people are running under their conditions
    Build date 9/25/15
    City water for fill
    May 2015
    Land O Lakes, FL
    527
    I am running mine 10 hours at 65 %.. Tampa FL, with screen enclosure and full sun from about 11am. Each day is different, some require more ppm and some require less. . I am still getting mine dialed in but am getting really close
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
