Thread: Has the riddle been answered
    Jun 2016
    HOUSTON/ TEXAS
    42
    Has the problem of the wall mount skimmer by intex rising up ever be solved
    Many Thanks & Great Days to All
    Miniman
    6981 Gallon 18 x 52 Intex Ultra Frame AG, Intex Krystal Clear Sand Filter Pump 3000 GPH, INTEX 120V Krystal Clear Saltwater System, TF-100 Test Kit, Intex Auto Pool Cleaner
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    Re: Has the riddle been answered
    I added a weight to the bottom of my hanger bracket (about 5lbs).
    It is the only thing I could think of doing.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    How about adding a rock?
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    The whole skimmer (bracket and all) wants to float. It isn't just the basket.
    I went nuts for a while coming home from work to find that it had rotated up and was floating on top of the water, and my pump was sucking air.
    I do like using the over the wall skimmer, as it allows me to fill my pool to the max. With a through the wall skimmer, my water level would have to be at least 3" lower than it is now (probably more).
