Thread: Does the ground really need to be level for Intex AGP?
    Hi. I'm new to this site and need some help. I do apologize if this has been discussed, I just can't find it. We're looking to get an Intex AGP, probably the 14'x42" metal framed one from TRU. Our lawn is not "perfectly" level. It slopes just so slightly (and I mean SLIGHTLY) away from the house so we may end up with about 1" difference in water level from one side to the other. I know it's not recommended by Intex, but can we get away with it? Please share your experiences with this.
    32' Kidney Shaped Pool. 16' across. 20,000 Gallons. 3' to 6' deep. Saltwater System, Sand Filter. Intellichor.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    890
    Re: Does the ground really need to be level for Intex AGP?
    Quote Originally Posted by we_say!
    I always thought my back yard was flat...but once you set up your intex it will show you just how off your yard is..I had the blowup tube pool with the vinyl sides. My intex always had about a two inch difference between the left front and the right rear. This is where the slope was. This really can be a hassle if you have too many swimmers or someone leans to hard on the tube too hard, it can cause the pool to collapse. However since you are getting the metal framed pool, I would say a difference of 1 inch or less would not be a problem. Just make sure that the skimmer is one the side that the water flows to. You could run into issues there with the skimmer being on the high side rather than the low side...I would try to make sure it is centered as best as you can right in between the two levels...Other than that you should be ok.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,965
    Good point, about the location of the skimmer.
    Yes, we had our pool "professionally" installed, and they charged extra for levelling the yard.
    The water is off a good 1 1/2 inches, after the professional levelling job.
    http://www.PerfectlyClearPoolService.com
    Casey's Avatar
    SW PA
    10,163
    I would take the time to level it. I did my pool myself and it ain't off a bit! It's just another reason why I opted out of the so called professional installation with a price tag that could make you poo bricks. I was afraid it wouldn't meet my standards too so I did it myself! 8)
    Dad always said, If ya want something done right, DIY!
