Thread: Maintaining TA in a new 35,000 gallon plaster pool
    May 2016
    Lenoir NC
    3
    This is a salt water system that is about 9 months old. I need to add a quart of acid a day to maintain Ph. If I try to increase the TA my acid usage goes up. Do I have to maintain a minimum TA if I have no low ph problems?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Maintaining TA in a new 35,000 gallon plaster pool
    No need to have a min TA unless below TA of 40 or so... I have mine between 50 and 60 and my PH stays around 7.6
    30,421
    Increase your TA with baking soda. It has little to no affect on pH.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Focus on your pH instead of it and TA. It's always going to be a roller coaster if you manipulate both, and doing so is seldom required.
    Essential Links:
