Thread: Using 3" trichlor pucks in Liquidator
    Jul 2009
    Prairie Du Chien, Wi (SW Wisconsin)
    24
    I have quite a few 3" trichlor pucks left over since my auto chlorinater broke; can I use them in my liquidator instead of liquid bleach so I can use them up? My CYA now is 30 ppm so using pucks to raise it to 45 or so seems desirable.
    56,000 gal in-ground vinyl liner, 22' x 44' with 10' deep dive well (only 8' long shallow end)
    1 hp Hayward Superpump, runs 24/7, 300# Hayward S244T sand filter
    Hayward H300 300,000 BTU LP gas heater, Rainbow auto chlorinator w/ check valve
    Liquidator liquid chlorine feeder, Polaris 380 pool cleaner with 3/4 hp booster pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Using 3" trichlor pucks in Liquidator
    No, never mix chlorine sources in any delivery device. If you want to use the pucks, put them in a floater.
    Support the site
    Donldson's Avatar
    NW Ohio
    2,892
    Safety aside, the liquidator is not an erosion feeder. The bottom of a liquidator, by design, has virtually no water movement. As such the trichlor will sit stagnant creating a very acidic stew of chlorinated water. Since the liquidator is designed to hold a high pH liquid it will likely be damaged by the acidic water.
    Good question, bad idea.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2009
    24
    So the best bet is to replace the rainbow chlorinator so I can use up the pucks then go back to the liquidator with Aldi's bleach.
    May 2014
    Franklin, NC
    9,184
    Use the Liquidator with Aldi bleach. Save the pucks for later, they dont go bad. I started with CYA=250 and a bucket of pucks. Three years later I'm floating the pucks for days out of town or just to bring my CYA up!
    Support the site
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,236
    I'd buy a bag of powdered stabilizer to raise the CYA and save the pucks for future. You can buy a chlorine puck floater for around $7. It just bobs around in the pool as the puck dissolves. It has a rotating thing so you can adjust how fast the water moves through it, kind of. They work adequately for an absence.
    Heritage Floating Chlorine Dispenser - Walmart.com
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
