Thread: SurfingCRNA - If I can do it anyone can
    May 2016
    Orlando/FL
    7
    Just wanted to say a quick hello and thank you to everyone whose posts I read over the last month. First time pool owner and the pool wasn't in bad shape but I've learned alot. After a couple weeks we are maintaining it by ourselves, I've taken apart, drained half the pool to lower the CYA and now have good chemistry.
    Thanks again and good luck everyone.
    11,000 gallon plaster finish in-ground pool with attached, elevated hot tub. Figure 8 shaped pool, 3 ft shallow end at 5 fet deep end. Pool enclosure. Raypack P-R406A-EP-C Propane heater. Hayward TriStar VS900, Pentair Clean and Clear 100 sqft cartridge filter. Borax. TF-100 with Speedstir.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: SurfingCRNA - If I can do it anyone can
    Hey there SurfingCRNA, welcome!
    You made it through Nursing school and CRNA school....pool chemistry will be a snap
    May 2016
    Orlando/FL
    7
    I'm hoping so. It's been fun and already learned a ton.
    Jun 2014
    15,227
    That water looks great!
