Thread: No Cell Power!
    May 2016
    Hopkinsville, Ky
    17
    No Cell Power!
    I found a video on YouTube and checked each step. Until it told me my rectifiers needed replaced. So installed new rectifiers. Still no power took my T-15 cell to a buddys house, and it turned right on. I did find a burnt solder on back of board. It was behind a relay. I was wondering how hard it would be to replace? Any help would be appreciated. Pic is of relay that has burnt spot behind it.image.jpg
    18x36 Grecian
    Haywood Variable Speed Pump
    Gold line Aqua Plus With T-15 cell
    Sand Filter
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: No Cell Power!
    Most of the time you just need to refloat the solder so it makes a better connection with the trace. Have you ever soldered before?
    Mark
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: No Cell Power!
    I'd re-solder that joint first.
    Including the information on what controller you are talking about in your signature or the post would help others that know these systems well though. Otherwise, if you found a bad solder joint and recognized it I'd try re-soldering it before swapping parts.
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Re: No Cell Power!
    Typically, resoldering works.
    Support the site
    May 2016
    Hopkinsville, Ky
    17
    Re: No Cell Power!
    Sorry Aqua Plus with T-15 cell. I have never done any soldering, but I guess I can try that first.
    18x36 Grecian
    Sand Filter
