Thread: triton plus not cleaning water line...help
    May 2016
    Vacaville, CA
    8
    I just bought a triton plus robotic pool cleaner. I need help..it is only cleaning for 1 hour and not cleaning the waterline. I know it can because I used the remote to get it up to the waterline. I may need to return it..Perhaps it is stuck on the option for a 1 hour clean which is controlled by the more expensive remote...but I have no way to control that or reset the device...any advice??
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: triton plus not cleaning water line...help
    Call the manufacturer's help line? Contact Customer Service - Maytronics US, Inc
    Jun 2015
    East Meadow NY
    12
    I have the triton plus. I got it last summer. I'm not an expert by any means but I think I noticed that the handle can be in more than 1 position. Try adjusting it. I think in 1 position it didn't go up to the water line and after moving it it did. After I turn on the power, I use the remote to start it. I select the pic of the clock with man going slow (left image) and it runs for 3 hours, going up to the water line. I use the arrow buttons to bring it to the shallow end so I can reach to take it out. I hope this helps.
    20 X 40 lazy L, vinyl liner, chlorine, approximately 33,000 gallons, automatic chlorinator, DE filter, HP 1.5 variable pump, dolphin Triton cleaner
    cleaner
