Thread: Increasing CH level
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Increasing CH level
    Hello All,
    I need to add about 16lbs of Calcium Chloride to my 17K plaster pool, its currently measuring at approx 250 and will bring it to 350 and remeasure. Being in Florida getting deicer isn't the easiest thing to do, but the internet is my friend and Homedepot is close by: 25 lb. Professional Strength Calcium Chloride Pellets Ice Melter - Re-Sealable Bag Model # 206402769 $16.99, with FREE SHIPPING to store.
    Looks like a winner at 94% Calcium Chloride.
    5lbs of CH increaser is $10, so it seems like a no brainer.
    Hope the info helps others.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Increasing CH level
    Don't bring it up to 350 keep it at 250ppm. Fill water usually adds more CH also so it will increase on it's own.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    wjr75, don't forget down here we get 50-65 inches of rain a year, depending on where in FL and it has no CH at all.
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Quote Originally Posted by bobodaclown View Post
    Hello All,
    I need to add about 16lbs of Calcium Chloride to my 17K plaster pool, its currently measuring at approx 250 and will bring it to 350 and remeasure........
    What is the CH of your tap water?
    I don't know the age of your pool. Did you add Calcium Chloride in the past to bring level to 250?
    My tap water is CH 75. My new pool will be filled hopefully next week and I don't think I'll need to add Calcium Chloride because the new plaster should raise the level.
    But, if I have to use some thanks for Home Depot order info.
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    Apr 2011
    Murrieta, CA
    2,360
    Pool is old, and added CH in the past.
    Apr 2011
    Murrieta, CA
    2,360
    Product came in, added enough to bring my CH to 375. Poured in about 16 lbs directly from bag to pool. Dissolves in less than 15 minutes measured about an hour later. Quick and inexpensive compared to pool store pricing of CH increaser. Did not cloud up, kinda surprised.
