Results 1 to 10 of 10
Thread: Thought I had it right... :(
    andyrob2215's Avatar
    May 2014
    Portage, Indiana
    127
    Hi all,
    So I have a party coming in a few hours and have a cloudy pool for the first time in 3 years. Never had a problem with anything before.
    FC 6
    CC 0
    CYA 50
    TA 100
    PH 7.5
    not sure what's going on
    OCLT last night had less than .5 loss. So confused!!
    21'x52 AGP 11200 Gal
    TFPC Method
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Thought I had it right... :(
    Make sure your filter is back washed and bring up the chlorine close to shock level for your CYA is all you can do at this point.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2014
    Portage, Indiana
    127
    Is it safe to swim in? I know it's not if I bring the FC up that high
    TFPC Method
    Jun 2014
    15,208
    As long as you do not exceed the SLAM level of "20" for your current CYA, it is safe to swim.
    May 2014
    Portage, Indiana
    127
    Any idea what could be causing this? I've made sure to have at b least 4 Ppm of FC
    TFPC Method
    Jun 2014
    15,208
    Not at this point. That is odd. Your numbers above look very good.
    May 2014
    Portage, Indiana
    127
    That's what I thought. ..
    TFPC Method
    May 2014
    Portage, Indiana
    127
    Woke up this morning to find it as clear as ever. I brought the chlorine up to about 15 and left the pump on. Weird it cleared up so fast, but I'm not complaining. Thanks for the help.
    TFPC Method
    Jun 2014
    15,208
    Glad it changed for the better. Enjoy.
    Casey's Avatar
    SW PA
    10,453
    You probably didn't have enough chlorine.
