Thread: Estimating chemicals for extra swimmers
    May 2016
    CA
    29
    Good Morning! Do you recommend adding more chlorine than recommended on the chart when more swimmers than normal are expected? We are expecting about 20 or so tomorrow for the 4th and I was just wondering if the target FC is good, or if we should add extra chlorine to account for the extra swimmers...9-10 of those will be kids. Do you also recommend bringing pH down closer to 7.2, since there will be lots of splashing, or do you just leave alone as long as it's within the acceptable range? Most recent test results, just for fun
    FC: 4.5(adding more here in a bit to bump up to 7 for today)
    CC: 0
    pH: 7.5
    TA: 90
    CH: 300
    CYA: 70/75ish
    Pool finished in March 2016, 25k gal, white plaster IG pool, Pentair Clean and Clear Plus Cartridge Filter, Pentair Intelliflo 2 VST Variable Speed Pump, Polaris 280 Pressure Cleaner with Pentair Booster Pump, Natural rock waterfall with Pentair Waterfall specialty pump, Spa: Mastertemp 400 High Performance Heater, TF-100 Test Kit
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Estimating chemicals for extra swimmers
    For a big party I always bring my FC up about 2ppm above the top end of the target.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2016
    CA
    29
    Quote Originally Posted by wjr75 View Post
    Thanks! Will shoot for that when we have everyone over.
