Results 1 to 19 of 19
Thread: starting over and need help
    Jul 2016
    Lake Charles, LA
    10
    Intex 15x48 metal frame pool approx 5,300 gallons.
    I just drained it cleaned it, replaced hoses and it is filling up now.
    Hoses had cracked, pool turned terribly dirty.
    What do I do to start? I read somewhere about Bleach Borax Baking Soda and purchased all 3 today.
    The filter is a Hydrotools #71225 sand filter.
    The pool is almost full, test kit ordered.
    What can I do today? How much in what order to add?
    Can we get in it tomorrow? Currently I only have test strips and am on well water.
    Please give me some help, I don't want to start over again.
    Slandry
    Correction-
    15 x 48 Intex above ground metal frame pool estimated 5,300 gallons.
    Hydrotools sand filter purchased model #71225.
    Lake Charles, Louisiana
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: starting over and need help
    Welcome to TFP!
    Order your test kit at TFTestkits.net. A TF-100 is recommended, but a TF-50 might work for a smaller pool, Pool School - Test Kits Compared
    Follow along on this until the test kit arrives, it will get you started.
    Pool School - Guide for Seasonal/Temporary Pools
    Jul 2016
    Lake Charles, LA
    10
    What about this BBB method? Can someone tell me how much of each to put and the steps for 5,300 gallon pool until test kit comes in?
    My pool is almost done filling up and I have to do something today, it is very hot and humid here. 91 heat index 102!!
    Slandry
    Correction-
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    Get some bleach, most use the regular unscented 8.25% from walmart. OR... WalMart should also have pool chlorinating liquid in the pool section, that is what I use. Its a bit stronger than bleach at 10% so it takes a little less, and it's actually cheaper at my local store. Add about 24-32 ounces to your pool by pouring a small stream right in front of the return jet. You need this amount because, it takes about 6.5 oz of the 10% pool chlorinating liquid to raise 5000 gallons of water 1 ppm. I would start out in the 4 range and see how quickly it falls off. You want to keep FC above 2 at all times. Shooting for 4-5 will give some cushion as the sun and or swimmers consume the chlorine.
    Pick up an inexpensive 2 way test kit so you can verify PH and Free Chlorine. You want your PH to be in the mid 7 range and Free chlorine to be in the 4-5 range.
    If your PH is out of range you will need to adjust it. Low PH means the water is acidic and can damage your equipment, and high PH is not much better. You can buy what you need in the pool section or read pool school for alternatives.
    Don't use chlorine tablets or bags of shock, or really any dry chlorine product. These add things you may or may not need and will cause calcium or cya to build rapidly. Some cya is desirable but too much neutralizes your chlorine making you need to maintain a much higher level. Wait for your test kit, it will tell you what the pool requires. It will allow much more accurate testing of FC and performs several other tests that are crucial to proper balance.
    That's it, with fresh water your pool should be fine to swim in immediately. The sun and swimmers will consume your chlorine, so keep watch and add as needed. If you shoot for 4-5 ppm and check it each night, add chlorine as needed to maintain that level and you will be fine when your kit arrives. Your pool is safe to swim right after adding chlorine, just pour it in as described, leave the pump running for a while to allow it to mix in.
    Read pool school, this is actually fairly simple but there is much to learn.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    Jul 2016
    Lake Charles, LA
    10
    Thanks so much, I had read somewhere to start with a gallon of bleach.....I appreciate this feedback.
    Slandry
    Correction-
    Jul 2016
    Lake Charles, LA
    10
    What does anyone use for the CYA? I have read pros and cons about using it. Does anyone ONLY use bleach, borax and baking soda?
    Is there any routing weekly maintenance of adding to the pool or is it strictly testing every day or two?
    Do most of you use the chlorine tablets also? I am looking for the best KISS (keep it simple sister) method out there and appreciate any and all feedback.
    Slandry
    Correction-
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    You can buy stabilizer or conditioner to add CYA. The borax, soda ash or aeration is used to raise PH and muratic acid to lower PH. Baking soda to raise Total Alkalinity. It does not really take a lot of chemical beyond bleach, I have found. My tap water is pretty near perfect, I have only needed to boost PH once, add my chlorine doses daily and add CYA once.
    Chlorine tablets or most other dry chlorine products add CYA with every dose causing it to quickly build up to undesirable levels. You can feed the pool tablets or even a bag of dry shock now and then if you want to raise your level, but you have to monitor carefully.
    While some CYA is desirable, you don't want too much. The higher the CYA level, the higher you must maintain Free chlorine. If you need to reach shock level of free chlorine along with high CYA you might buy bleach by the truck load. If you get too much CYA the only solution available for most of us is drain and refill. You must add it carefully and monitor the results so you don't overshoot.
    It's all in pool school! in order to really keep track of whats going on you must have an accurate test kit. The cheap kits at wal mart won't give the whole picture. You need quality information to decide what the pool needs. It may seem expensive, but it will save money over time. Get the kit mentioned above or the Taylor k-2600, I have the speed stir also, makes adding drops while swirling a piece of cake. Check out these videos. The dpd-fas test for FC is very different from the simple kits, much more accurate and you can test much higher levels quick and easy.
    Jul 2016
    Lake Charles, LA
    10
    Test kit is ordered, may come in today using strips until then so far 3 days of test strips:
    TC.5-1
    FC 0.5
    PH 8.4
    TA 180-240
    CYA 30-40
    Slandry
    Correction-
    Jul 2016
    Lake Charles, LA
    10
    I am trying and reading and re-reading the pool school information. Is there a particular stabilizer or conditioner you prefer?
    How do I determine my daily dose amount of bleach, is there a rule of thumb to add XX ounces daily for a 5300 gallon pool or strictly by testing?
    Slandry
    Correction-
    triptyx's Avatar
    Apr 2016
    1,438
    There's no rule of thumb because chlorine consumption depends on a large number of factors.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    DFW, TX
    24,497
    We prefer granular stabilizer to liquid because it is way cheaper. I get mine at Lowes. Here is how to add CYA and other chems, Pool School - Recommended Pool Chemicals
    Yes, we recommend testing and then adding what you need to get back to your target level. But, test strips are a waste of time. Just wait for your good test kit.
    Jul 2016
    Lake Charles, LA
    10
    If all is looking good except the PH is above 8.4 and the chlorine is not staying up, should I use the acid to lower the PH or just continue adding the bleach?
    Slandry
    Correction-
    Jul 2016
    Lake Charles, LA
    10
    Test kit arrived, is the CYA mixing bottle supposed to be punctured or cut to drop the mixture into the tube slowly? I wasn't sure so poured it in the tube but could always see the black dot. Maybe it should be a very slow process? HELP please....
    Slandry
    Correction-
    triptyx's Avatar
    Apr 2016
    1,438
    The CYA test will cloud whether poured from the mixing tube, or squirted. You'll want to snip the end of the "squirter" tip with scissors if you want to use it.
    Not having any cloudiness means that you have less than 20ppm CYA, which is normal with new fill water. You'll need to get some and use PoolMath to calculate the amount to add to your pool. Start by targeting 20ppm, and then work up to 30ppm (or whatever your target) from there.
    DFW, TX
    24,497
    It is important to keep PH between 7.2 and 7.8 at all times.
    Jul 2016
    Lake Charles, LA
    10
    Slandry
    Correction-
    triptyx's Avatar
    Apr 2016
    1,438
    Quote Originally Posted by triptyx View Post
    Please see my response above.
    Jul 2016
    Lake Charles, LA
    10
    Thanks, I tested 0 for chlorine this afternoon and 0 for CYA. Added more 8% bleach according to the pool math and found granular cyanuric acid. Added 29 oz of that in a sock hung by incoming water inlet. If it takes too long to dissolve should I let it mix in the pool water or dissolve it and pour it in?
    Slandry
    Correction-
    triptyx's Avatar
    Apr 2016
    1,438
    Massage the sock while it sits in front of the return with your hand - it'll dissolve faster than you think. I tend to massage my sock until the thick, white cloud stops coming out, then I let it soak for a few more hours and massage it again. You can dissolve it fast that way. Don't just pour it in.
