Results 1 to 10 of 10
Thread: Pool heater
    Pool heater
    Hello
    Hopefully I'm in the correct forum. My pool heater which is electric started yesterday and sounded like a very loud wood chipper. I quickly turned off the breaker. The fan was moving and I didn't see that it made contact with anything. The fan however did wobble somewhat on the motor shaft and taking it apart ( fan from motor ) I couldn't see how it could be tightened up any, it wouldn't snug up any more than what the set screw was set for. So as of right now I suspect the motor, am I correct??
    Thanks
    Tom
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Pool heater
    Sounds like bearings to this I hate motors person. Someone will help you though. Whats the make and model of it to help them out?
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Pool heater
    It sounds like this is a heat pump. I would call an HVAC guy out to take a look. Sometimes those noisy fixes are easy fixes. It is also probably time to check the refrigerant level and make sure everything is in good shape.
    Re: Pool heater
    Ok Thanks
    It's an AquaComfort heat pump for a large built in pool. With the fan and motor removed can I start it to see if noise is gone?
    Thanks
    Tom
    Re: Pool heater
    FYI. I did run the heater for 30 seconds without the motor and fan and all is 100% quiet. The set piece under the fan with set screw and the ring on opposite side has slack making the fan loose or wobble. I'll take both fan and motor to a small motor repair shop on Tuesday.
    At the bottom of the enclosure I see a soda can size container that sits over a copper tubing that has a crack, I'll post a picture later or tomorrow. Will power wash the unit while it's open. It is going on 8 years old
    Tom
    Re: Pool heater
    ? Anyone
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,830
    Re: Pool heater
    Don't power wash the fins in the unit you will destroy them. If you are dead set on cleaning them get some condenser coil cleaning solution and gently spray it and and gently wash it off with a garden hose. It's a good catch on the fan motor that should be an easy fix. And you will be back to the quiet operation you had before. If it's anything like mine that's very quiet.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Re: Pool heater
    So should I spray the outside and than use the garden hose from the inside to force the dirt back out?
    Tom
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,830
    Re: Pool heater
    That will work just don't bend any of the fins.
    Chuck-
    Re: Pool heater
    Just dropped off the fan motor and fan. The play in the fan was the primary source of the noise but there is play in the motor shaft ( up and down but not side to side ). So new fan and the motor will be serviced. Not sure if one caused the other
    Tom
