Thread: Pressure pump pressure relief purpose?
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    I'm just wondering about the pressure relief on my Polaris wall fitting. Is that to protect the Polaris, simply to have the "correct" pressure where the Polaris works best, or does it protect the pump?
    I haven't had anything to mess with on my pool for awhile and bored so going to make an attempt at a DIY aerator just for any possible future use. I "think" a pump should be just fine as long as water is flowing at all, but wanted other input. I'll be connecting it with a universal wall fitting like Skippy's fountain but instead of adding the valve just cap it off or connect a ball valve there so I can adjust the flow.
    I have some parts ordered already. I will tee it after the fitting. On both sides will be another tee and a 45 on the end, each of those going to a 3/4 ozone/irrigation venturi valve so a total of 4, inside two straight out and outside ones out by 45.. Airline connected to each, connected together, and extended out of the water where I can also adjust the air.
    Will be awhile, and no clue how well it will work, but at least something to mess with With a 300 gallon reef tank for many years I got to thinking about the venturi used to make the fine mist of bubbles for the skimmer.
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pressure pump pressure relief purpose?
    sounds interesting, pictures needed
