Thread: JAndy aqua link RS. No power to transformer
    Jul 2016
    Dallas, TX
    1
    Board is completely dead. Fuse is ok. Gfi plug from power source is good. When I check for current going to transformer it doesn't register. The transformer gets its power from one of the relays and it shows no power going to it but the two relays next to it show power. Any ideas?
    Jun 2016
    Martinez, CA
    207
    Re: JAndy aqua link RS. No power to transformer
    Transformer is typically wired directly to a dedicated circuit breaker in the power panel. It doesnt go through a relay as it controls the power to the relays. If you arent getting power to the transformer, the controller won't work as well as any buttons on the panel. Trace as to why the power to transformer is not hot. Likely a tripped breaker or loose wire. Normally white wire to neutral buss and black goes to hot side of breaker.
    Sounds like your controller is wired with a gfi protected plug in outlet so likely they just connected to the hot side of one relay to tap into constant power? Take some pics of the panel open and feeder to the gfi so we get a better und rstanding of how it is installed. If you arent confortable working with electrcity, an electician will likely get you up,and running pretty quickly. Good news is restoring power to,the transformer will likley fix your problem and is much cheaper than replacing the controller board!
    Do you have a factory surge supressor installed? If so, there may be other causes / wiring will likley be different than described above.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
