Thread: pump making noise and not pumping
    Jun 2016
    ROANOKE, VA
    9
    I am new st this. Need help on my pump. It is a cartridge style. The motor was making a loud humming sound and now it is a high pitched sound. The pump doesn't do anything. Help!
    Jake
    13,500 gal AG vinyl soft sided pool (Pro Series), 24' round, with CP2000 cartridge filter/pump. NEW POOL OWNER. was using Baquacil and converting to chlorine
    Jul 2015
    Houston, Texas
    1
    Re: pump making noise and not pumping
    Sounds like a bad capacitor on the pump motor. You can get it tested at the pool supply store. Make sure you cut off the electricity before u remove it from the motor. Also it can carry a charge by itself so u need to discharge it. If you're not comfortable messing with it take the whole motor to the store. Again make sure you turn off the electricity at the box before touching the motor.
    Jun 2016
    ROANOKE, VA
    9
    Thanks. the pump is brand new. maybe been in use about 5 weeks total. I will figure out what the capacitor is and remove it.
