Results 1 to 8 of 8
Thread: HELP passing OCLT
    Jun 2013
    Laguna Niguel, CA
    4
    Exclamation HELP passing OCLT
    I am still unable to pass OCLT despite running for 3 weeks now. My intention is to SLAM and then super chlorinate for mustard algae. I had a really bad bloom I could not get on top of for a long time. I have been through about 24 gallons of chlorine to this point. I'll post some more detailed numbers tomorrow as I have just added chems but is there any other possible cause of CL drop apart from organics or sunlight? Is there another option I could consider to rid myself of organics?
    CYA: 50
    FC: 6 down from 18 in 3 days but just added CL
    CC: 0.5
    PH 7.5
    19000 gal, plaster pool. SoCal.
    IG, Plaster, ~19000 gallons (1986) with spa and barstools, Pentair Clear Filter cartridge totaling 420 sqft, 1 HP WhisperFlo pump, Zodiac Barracuda G3 suction cleaner, PoolSkim.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: HELP passing OCLT
    How much are you losing overnight? Are you testing before the sun is up? Have you checked all the nooks and crannies, and scrubbed there? Brushing regularly? How often per day are you able to test and dose? The more you don't let it fall below target, the sooner it ends. If you regularly fall well below, you are really maintaining the SLAM. The SLAM target for a CYA of 50 is 20.
    Jun 2013
    Laguna Niguel, CA
    4
    3-5
    30-45 mins after sun up
    As much as possible I have scrubbed and scrubbed and brushed and scrubbed almost daily - sometime I miss a day. I have cleaned the cartridges once a week too.
    I can only test and dose twice a day during the week but with the exception of the last few days, I have been at SLAM for about 2 straight weeks. The first week would drop way below really quickly due to all the algae.
    Obviously the local dealer is pushing all sorts of chems but would it be worth considering removing the phos or is that another waste of time?
    Aug 2014
    Northern IL
    4,615
    Do not go to the pool store anymore. They will just confuse you.
    Your shock level is 20 with a CYA of 50. That might be part of the problem. Get it to at least 20 and keep it there.
    Jun 2013
    Laguna Niguel, CA
    4
    Raised it back to shock after after weekend and it passed the OCLT last night. Thank you all for supporting me through through my own self doubt and pool store induced confusion.
    Raising to Mustard Algae levels now...
    Aug 2014
    Northern IL
    4,615
    Great! Did you get it all the way to 29 FC?
    Jun 2013
    Laguna Niguel, CA
    4
    I did and a bit beyond.
    I have had recurring mustard algae for over a year and could never commit to keeping on top of it. It was a multiple daily process. I went through gallons and gallons of chlorine, cleaned the cartridges half a dozen times, swept daily but, since then, no problems whatsoever. Its crystal clear, easy to maintain and the pool we always wanted. Another plus is that my arms and my (farmers) tan are looking pretty good too!
    The advice/school on here has been invaluable. Thank you!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by Billy_McSkintos View Post
    It only works if you follow it correctly! Congratulations in your TFP pool!
