Results 1 to 14 of 14
Thread: Suggestions for upgrade: AG pool is going to be taller than deck
    Scrappnchick's Avatar
    May 2015
    New Martinsville, wv
    17
    This is a 16 X 48 intex pool. I decided I'm too old to put this thing up and down every year. So next year we'd like to get a actual AG pool. They are all 52 inch tall. I love my deck, what should I do? Has anyone every remodeled a deck to fit a different size pool? Regular pools also come in 15 round and 18 round NOT 16.
    I'll take any suggestions.
    Hayward pump, filter and gas heater
    Aquabot poolrover cleaner
    13000 gal. 15x30 AG
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,453
    Re: Suggestions for upgrade: AG pool is going to be taller than deck
    My pool is taller than my deck. I built it that way because I'm getting to old to be crawling under it to pull the winter cover under the deck.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I got the 26' Intex. I don't take it down. (Didn't take my 18' down either.) it survived that super cold winter two years ago with no ill effects.
    Jun 2015
    Stockholm, Sweden
    250
    Keep the pool and leave it up.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Apr 2016
    Massachusetts
    20
    Whatever you decide on doing with the pool, you should think about adding some kind of wall or gate. It looks pretty easy for a little one to get loose and just climb the steps and fall in the pool. Even just putting rails on the steps with a door at the bottom or fencing the entry in a little could work. Terrible thought but with pools, safety should be the first concern.
    Good luck.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    575
    I was in the same situation as you when it came time to upgrade to a more permanent pool. The old one was 48" tall and the new was 52". I didn't want the deck shorter than the pool so the only option was to dig out the ground and lower the pool. Luckily the slope of the land ended up still working in our favor and the low side was almost right at the perfect elevation, but we also went bigger so it went out farther.
    Your situation may not work out the same if staying with the same diameter. If you know the finished height of the top rail then using a transom or laser level and digging to the right depth wouldn't be so bad to get it to line up how you have it now. It's just a little more challenging, but it can be done. Trust me!
    Also wanted to point out that going from 18 to 24 only required slight modification of the deck. But ours doesn't go around as much as yours. And since like you said they don't do 16' putting an18' will probably result in a gap more in the middle of the deck between the pool. If you put the pool in where it is taller than the existing deck than that would definitely make it easier to frame a small step up all around and cover any unsightly gaps as well as visually blending the new pool into the old deck.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    May 2015
    17
    Quote Originally Posted by Mickelin View Post
    That's what I'm leaning toward!
    Quote Originally Posted by IsThisWhereIPutMyName? View Post
    Good luck.
    I live in the country. No little ones around. My neighbors are two eighty year olds. But I should probably still do it.
    Quote Originally Posted by PAGirl View Post
    Thanks for letting me know. I always wondered if it could make it through a tough winter.
    Quote Originally Posted by Jamison04 View Post
    Thanks for the suggestion, I had never thought of doing that!
    13000 gal. 15x30 AG
    TF-100 test kit
    30,429
    I don't think you'll find the extra 6" much of a bother. If you do, it would be fairly cheap to build a step-up on top of the deck that would match the height of the new pool.
    kk_isme's Avatar
    Aug 2015
    North Central Texas
    108
    My pool is taller than my deck. I didn't want to be on display for the neighbors, so we built the deck halfway as tall and built steps to attach the pool steps to. I'll take a pic and post tomorrow. It works for us.
    14,000 gallon above ground 24ftx56in round vinyl overlap liner steel wall sand filter 1/2 hp pump heavy lime in city water morning shade
    Larryh86GT's Avatar
    Jan 2015
    Western New York
    93
    I agree. I left my Coleman steel frame pool up this past winter and it came through just fine. I couldn't see myself taking it down and putting it up each fall and spring. If it only lasts 3 or 4 years I will get another one. (Plus my new deck fits the pool too).
    Coleman 16' x 48" power steel pool.
    May 2015
    17
    Quote Originally Posted by Larryh86GT View Post
    I loved my old Intex pool, It lasted 4 years before it the ladder rubbed a hole in the bottom of it. (my husband put the ladder in backwards) I went to 4 stores to find exactly the same one. Well, the picture on the box was the same, but the pool had been "improved". They ruined them! It has a convoluted hose assembly. It leaks around the connector valves. I've used a lot of the parts from the old pool to "repair" the new pool and it's only the second year we've used it. I'm glad some of you have said you just leave up the pools over the winter. I'm going to try it.
    Quote Originally Posted by kk_isme View Post
    Can't wait to see the pic. I'm trying to visualize it.
    13000 gal. 15x30 AG
    TF-100 test kit
    kk_isme's Avatar
    Aug 2015
    North Central Texas
    108
    WIN_20160705_150224.jpgHere ya go.
    Ignore the bench section in the background. That was a miscommunication between me and the builder and is going to be taken out and a rail section installed soon.
    May 2015
    17
    Here ya go.
    Thanks so much for sharing!
    13000 gal. 15x30 AG
    TF-100 test kit
    May 2015
    17
    I was wondering if you put a pool pillow in it before you put the winter cover on? Can the intex support legs handle the winch thing that keeps the cover on?
    13000 gal. 15x30 AG
    TF-100 test kit
