Results 1 to 8 of 8
Thread: Mistcooling Pool Cooler
    Apr 2014
    Mobile, Alabama
    75
    So I'm thinking about trying one of these Mistcooling Pool Coolers:
    Amazon.com : Pool Cooler : Automatic Lawn Watering Equipment Accessories : Patio, Lawn Garden
    My pool has two returns so I assume I should just one of these as I assumed the circulation would be compromised if both my returns had these attached. Anybody used these? I searched the archives and it appears some people had success.
    Kevin T
    16' x 32' Vinyl Liner Grecian Pool. 20,000 Gallons. Sta-Rite SuperMax 1HP Pump (PHK2RA6E-102L). W. Cooper Ranger Series 25" Sand Filter. Dolphin Nautilus Plus.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: Mistcooling Pool Cooler
    Build your own with some PVC.
    I say PVC is like tinker toys for adults. Got a drill? Buy the fittings and build it. 1/16th drill bit works for the sprinkler.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Feb 2015
    Chandler AZ
    924
    Nice idea - but you could easily build one for a LOT less money. And, if you've never worked with PVC before, this would be good practice in case you ever needed to do any repairs/replacement at your equipment pad.
    Be aware that using it a lot will cause your pH to rise do to the aeration.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Check out Skippy's cheap pool cooler (link in my signature line)
    Apr 2014
    Mobile, Alabama
    75
    Thanks. I actually made a pool aerator for when I need to lower TA, but it wouldn't work for cooling. I might just try my hand with PVC. I'm always fighting high pH though so I'll have to weigh cooling vs. even more increased pH. But there's nothing worse than slipping into a pool that feels like tepid bath water. Water is 88 degrees right now and this summer is barely starting.
    Kevin T
    May 2015
    Fort Mill, SC
    179
    I bought this one on Amazon and have been quite pleased with the results:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    20K gallon vinyl inground pool, Hayward Pro Series sand filter, 1 HP pump, Taylor K-2006
    Apr 2014
    Mobile, Alabama
    75
    My wife actual bought that same "fountain" at our local pool store. I have it hooked up now and will be running it at night. I'm going to use it at night for a week and see what effect it has on water temp.
    Kevin T
    Apr 2014
    Mobile, Alabama
    75
    Well that didn't go as planned. Apparently some time in the night, the water pressure blew the sprinkler off of the fountain. Guess I should've put it on the lower pressure return. I'll tighten it down and try again tonight.
    Kevin T
