Results 1 to 8 of 8
Thread: Pool Heat...Does Anyone Make a Pool Chiller
    Feb 2016
    McKinney. TX
    42
    North Texas. Pool water temp today was 94. Daytime temps going to be at or around 100 next week with "lows" around 80. I've heard a tale that someone around here has a few "black box" solar panels hooked into his pool circulation system. In the winter he uses it to heat his pool. In the blazing summer, he circulates his pool water thru it at night, which allegedly turns the black boxes into radiators and "cools" the water. Anybody heard of this or other ways to cool the pool?
    My older sister claims I live in H_ll (due to the sumer high temps). I plan to get 50 lbs of dry ice, toss them into the pool, take a pic to show her how the pool water "boils" in the summer............
    12,000 gallon, in-ground, Lunar Quartz-Bermuda finish. Pentair Intelliflo Pump and Pentair cartridge filer. Polaris 280 pool sweep. Circupool SJ40 SWG.
    Apr 2016
    Houston, TX
    208
    Re: Pool Heat...Does Anyone Make a Pool Chiller
    2016 pool build.... 18k gal. freeform style, built in round table, 18" jumping platform, travertine coping upgrade, travertine waterline, peagravel decking, saltwater pool (no spa), Quartzscape blue., 1.5hp Pentair pump, JANDY SWG, 48sqft Pentair DE filter, TFP-100 kit w/speedstir MYPoolBuild
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    My husband Skippy built a real nice, cheap cooling fountain- check it out Skippy's New Fountain
    Yip
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Quote Originally Posted by vetman85 View Post
    You CAN achieve some water cooling by setting up a sprinkler screwed into a return. Another poster here had the same question not long ago. They posted this link. Amazon.com : Pool Cooler : Automatic Lawn Watering Equipment Accessories : Patio, Lawn Garden
    But in all seriousness you can build your own with PVC fittings and a drill. I have one that I built and I'm constantly experimenting with height etc. the key point is to run it overnight when air temps are cooler than pool water temps.
    And yes......you are losing water to evaporation when you do it.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad pooldv's Avatar
    DFW, TX
    24,490
    I run my solar panels at night to keep the pool between 89 and 91. Glacier makes chillers. And many heat pumps also cool pools.
    May 2015
    katy, tx
    31
    Many years ago (20 or so) we ran something similar to skippys posted above for an Olympic size pool I managed in high school. It was much larger. I built the same for my pool, plugged it into a bubbler, plugged the other bubbler hole and shut off all the other returns. Last night in about 12 hours I dropped from 94 to 87 degrees. The main thing as I can tell is push a lot of water through and push it as far across the pool as you can. The higher the better as well. I've tried a few different designs and those characteristics are what have worked best so far. I generally only do it on weekends as I get free electricity on the weekend so running the pump full speed is no big deal during the weekends.
    16,500 gallon in-ground pool and spa with Quartzscapes Midnight-blue and pretty sparkles
    Aqualink RS with PDA
    Jandy Pro Series Plus HP 2 HP 2 Speed Pump
    Jandy CV460 Cartridge Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Just a simple screwed in plastic "flower" aerator drops my pool 5 or 6 degrees overnite.
    wjr75's Avatar
    Jun 2013
    IL
    836
    If you are made of money they sell swimming pool chillers. I googled it and Glacier comes up as a vendor. We don't have that problem up here in the Midwest.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
