Results 1 to 7 of 7
Thread: Pentair multiport valve issue?
    Apr 2016
    Youngsville, LA
    274
    I noticed today while my pump was running in routine "filter" mode, that a small amount of water was dripping out my waste pipe by the road (I noticed the ground was a little wet and it hadn't rained in a while). So I inspected the multiport valve (not sure if this is the correct term for it) and noticed that the looking glass was half full with water also. The multiport valve and handle was changed only a few months ago (I think 3 months), so it's relatively new. What could be the issue guys? Praying it's a simple fix! I know water shouldn't being getting through the "backwash/waste/rinse" line when the valve handle is on filter right? I'll post some pics of my setup.
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin Nautilus Plus Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    Jun 2014
    15,212
    Re: Pentair multiport valve issue?
    Did you do the multiport valve replacement yourself or did you have someone else do it? I wonder if the spider gasket didn't become compromised somehow. Have you been careful to turn-off the pump when changing valve settings? Also, are you careful to move the valve in the "same" direction every time?
    Apr 2016
    Youngsville, LA
    274
    Quote Originally Posted by Texas Splash View Post
    Someone else replaced it before we moved in. I'm very conscious and ALWAYS turn off pump and move handle in same direction (clockwise) every time I use it. The guy who changed it (pool guy for previous owners) came by the house after we moved in and rubbed me the wrong way, so he wasn't welcomed back. He also did something shady that I won't get into. "Supposedly" he used a new setup multiport valve when he changed it but who knows!
    Jun 2014
    15,212
    Ugh. Well, that doesn't sound good. Let's give your thread here a bit more time for some others to respond with ideas. But at the moment the valve and/or gasket has me suspicious.
    May 2015
    Fort Mill, SC
    179
    I've had those issues and they suck. There are two possibilities I can think of for quick fixes. First, one of my valves was finicky about the direction it was turned. If I turned it clockwise to the "filter" setting, it would leak. If I turned it clockwise past the filter setting and then counterclockwise back to it, it would hold. Long shot but could help. Second, you could do a quick rebuild of it. Take it apart, lube the seals, then reattach the face with the proper criss-cross tighening pattern. The guy that installed it may have taken shortcuts. Again, probably a long shot but it will cost you only time.
    20K gallon vinyl inground pool, Hayward Pro Series sand filter, 1 HP pump, Taylor K-2006
    Apr 2016
    Youngsville, LA
    274
    Quote Originally Posted by C3Cl3N3O3 View Post
    The first fix seemed to work as of now. I went clockwise slightly pass the "filter" option (maybe 1/4-1/2"), then went back counter-clockwise and stopped it on "filter," checked the drain pipe and it appears water has stopped leaking. So we're good for now, if it starts leaking again, and I want to take it apart, do I simply just unscrew the 6 main screws holding the handle/faceplate down or is there any other steps or precautions I need to take before doing that (obviously the pump will be off)? What exactly am I looking for once I take it off, I'm assuming a gasket of some sort?
    Jun 2014
    15,212
