Thread: IC 40 Trouble
    Oct 2015
    Burleson, Texas
    178
    IC 40 Trouble
    The flow light is solid and the red and green salt lights are flashing. Manually tested salt at 3400. Opened the unit and found nothing in the blades but a rusty colored substance on the sensor. Any ideas?
    21,000 gallons, Salt, IG Gunite, Plaster Finish, Free From, Pentair FNS DE cartridge filter, Pentair Intelliflo-VS pump, Intellichlor IC-40, 2 port fountains, bubbler in tanning deck, Dolphin M400, TF-100, K-1766, Speed Stir
    JoyfulNoise's Avatar
    May 2015
    13,201
    Re: IC 40 Trouble
    That is not normal. I think you need a new flow sensor. If it's under warranty I think Pentair will replace the unit. Otherwise, the sensor assembly is a field replaceable unit (FRU).
    Matt
    Oct 2015
    Burleson, Texas
    178
    Re: IC 40 Trouble
    It was just installed in November so I'm good. Thanks for the help.
