Results 1 to 14 of 14
Thread: Blue water but pretty cloudy
    Jun 2016
    Clarksville Tennessee
    10
    Howdy tfp'rs I'm brand new to this site and have been attempting to soak up as much knowledge as I can (And I've learned a lot). Unfortunately I haven't been able to tackle this pool 100%.. On a good day the pool is like the cya test with the filter acting as the black dot.. In other words I can't see the filter on the bottom but I can see the bottom of the shallow end clear as day. there's also a slight film of what seems almost yellowish along the entire pool and there are large deposits along any angles (i.e. Where the shallow end starts declining) and after a thorough brushing it's just completely cloudy green. My tf-100 kit just came in today and I'm now confident enough to post a question lol. My results are as follows:
    Fc: 3.5 ppm, Cc: 0, Ch: 250 ppm, Ta: 80 ppm and Cya has apparently dropped to 20 from two weeks ago (Pool store test) from 30.
    Also Ph reads ~7.2-7.5
    ...so with this knowledge I suppose I'm just wondering if I do indeed need to perform the dreaded SLAM it or is it simply a matter of waiting until it clears completely? I've been making a solid effort of brushing daily and I'm running the pump 24/7 whilst back washing/rinsing every couple of days. All help is appreciated
    -Alex
    Alex, Tennessee
    29k Gallon IGP w/ vinyl liner
    Hayward sand filter
    Jun 2014
    15,218
    Re: Blue water but pretty cloudy
    Hi Alex and welcome to TFP! Yes, you need to "SLAM" (link below). As long as your pH is close to 7.2, start increasing your FC with regular bleach. I would actually add a little more stabilizer to get your CYA to "30", then adjust FC with bleach to "12". Maintain that and do everything on the SLAM page each day and you'll clear-up that water so you can see the drain once again.
    Jun 2016
    10
    Alright Pat I'll succumb to the SLAM lol, thanks for the advice and I'll update the thread with questions and/or results as they come across! Oh and thanks for the quick link too!
    Jun 2014
    15,218
    You can add bleach to the pool in-between baby feedings and diaper changes.
    Jun 2016
    10
    Haha when diaper time arises I'll go check the pool and look 'busy' but I do have a question.. I added nearly 4 lbs of stabilizer as per poolmath and I'm leaving the pool on recirculate as per bottle instructions but do I wait the 48 hours before adding bleach?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    You shouldn't need to wait 48 hours to add bleach.
    The thing with stabilizer is until it is dissolved, it may not register on a test. I think that may be why stabilizer instructions say to leave on recirculate.......in case granules get in filter UNdissolved? If you add it by our method......the sock method, I'd say that isn't the case. What's the sock method? Put it in an old tube sock to let it dissolve. I actually tie mine to a pool noodle and let them float.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2016
    10
    Uh oh :/ totally just did it bottle method.. The bottle also just said don't backwash throughout this duration so as to ensure maximum desolve
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by Cornhusker View Post
    It's fine, just don't backwash for a bit. The sock is just preferable.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Jun 2016
    10
    Update 1: No changes.. As per expectation. I'm going to wait the total 48 hours, swim a little for the 4th, then officially start the slam process. I appreciate all the help so far!
    P.s.- I purchased 6 large bottles of bleach knowing I'll need to use about 4 right out of the gate.. Is that enough to get me through this? Secondly as I add posts it no longer adds my signature.. What am I doing wrong?
    Jun 2014
    15,218
    You'll probably need more bleach. Once you get started and see how well FC holds up there at the SLAM level you'll get an idea how much you need each day. As for your sig, check your profile settings to ensure it is selected appropriately. Also, when you post, there should be a block at the bottom left that says "Include signature in post". Maybe one of those will help.
    Jun 2016
    10
    Hmm I believe it was because I was viewing this as the mobile site and not as the full site on my phone. That's my guess
    Alex, Tennessee
    Hayward sand filter
    Jun 2016
    10
    It seems as if it will be storming all week.. Should I go ahead and start slamming anyways or wait until the weather decides to comply?
    Alex, Tennessee
    Hayward sand filter
    Jun 2014
    15,218
    No need to wait as long as you are around to check FC.
    Jun 2016
    10
    Thanks for the help everyone, pool is crystal clear and blue as the sky!
    Alex, Tennessee
    Hayward sand filter
