Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Hayward pool heater knocking
    May 2016
    Dallas, PA
    46
    Hello all. New pool owner this year (bought the house with the pool). Got it going and have been using the pool for a few months. This site is awesome! Anyway, today our Hayward nat gas pool heater began to make a knocking sound. It happened about 20 minutes after start up. After doing some research it seems that I may have a broken bypass valve, or calcium build up in the heat exchanger. Hopefully it is the valve since that fix seems much cheaper!
    My question to you experts is this. I do not know what a normal condition for the heater is when I take the valve out and inspect, so what should I be looking for once I have the inlet/outlet pipes disconnected? Will I be able to visibly see a calcium issue if that is the case?
    Any help here is appreciated!
    20,000g, IG, Vinyl, Hayward 4820 DE Filter, Hayward Super II pump, Taylor K-2006 kit, Solar & NG heater
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Hayward pool heater knocking
    Make sure you don't have any valves that are preventing flow of water to the heater. If that is all correct, then I suspect you have a broken bypass. Which model heater do you have? Doe sit have a digital display?
    Look at this video I did a while back. It will help you understand what needs to be done.
    Hayward Broken Bypass Video - YouTube
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    May 2016
    Dallas, PA
    46
    Quote Originally Posted by ps0303 View Post
    Plate is ok and intact. Not sure where to look next. I could not see any visible issue with the heat exchanger. Could this be a thermostat issue?
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    You took the header off? If it's knocking and everything else looks good, it's a water flow issue. Do you have any valves associated with the pool system? Specifically near the heater? Sometimes there is a valve that can be used to bypass water flow from the heater and if not closed properly it will cause the hater to be starved of water and thus create the sound you are hearing.
    Paul
    May 2016
    Dallas, PA
    46
    There is a bypass valve before the heater, but it has been open and the heater has been running fine for months with no changes in the valve set up.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    When you say open, to me that means it is allowing water to bypass the heater. It should be closed to force water into the heater.
    How about a picture?
    Paul
    May 2016
    Dallas, PA
    46
    It is allowing water to the heater. The heater runs for about 20 min it does heat the water for that bit of time, but after that 20 min or so the banging starts.
    Can you post a picture?
    The bypass is probably allowing too much water to go around the heater rather than through it.
    Support the site
    May 2016
    Dallas, PA
    46
    This is the valve before going into the heater and the position it is normally in.
    May 2016
    Dallas, PA
    46
    The valve is allowing water to bypass the heater. You have to close the bypass to force more water through the heater.
    Rotate the valve 90 degrees clockwise.
    What model Super II do you have? Total hp?
    If it's a high hp pump, you might only need to close the bypass part way. You want enough water flow, but not too much.
    Support the site
    May 2016
    Dallas, PA
    46
    1 hp.
    What is the service factor of the motor? SF on label.
    Support the site
    May 2016
    Dallas, PA
    46
    8E06
    What is the pump model number (silver label on pump housing).
    Should be something like SP3007X10
    Support the site
    May 2016
    Dallas, PA
    46
    C48K2N143B3
    That's the motor. I'm mainly trying to determine if you should close the bypass 100 % or leave it open a little bit. If it's a really strong pump, it's better to bypass some flow to prevent erosion.
    Most heaters can handle the full flow without problems. The Hayward heaters seem to have more erosion issues from excessive flow than other brands.
    Most likely, you'll be fine closing 100%.
    Support the site
    May 2016
    Dallas, PA
    46
    I appreciate it! Thanks!
    May 2016
    Dallas, PA
    46
    One last question... On the right side of the header valve there are 4 wires 2 going into each module... When I pulled them, I thought there was a wire harness in the boot. I know which 2 are from the top and which 2 for the bottom, but I don't know for sure for each individual wire... Can't find anything on the Internet for it.
  20. Back To Top    #20
    As long as you know which two go to the top and which two go to the bottom, you're good. The individual wire can go on either connection.
    Support the site
