Thread: 6-Way Valve won't seat flush on sand tank
    Jun 2016
    Vancouver
    7
    Pump Model EC015110 Sand Filter with E.C.O
    First time build - 6 way valve won't seat flush to the top of the tank so I can't get the clamp bolt on. It acts like the center pipe is to long. The center pipe is not to high because the tank is empty of sand. What is going on?
    Pool: Intex Ultra Frame 12x24
    Pump: Model EC015110 Sand Filter with E.C.O
    Heater: Solar Pro XD2
    Pool maintenance: skimmer, telescoping vacuum, solar blanket
    Jun 2014
    15,093
    Re: 6-Way Valve won't seat flush on sand tank
    Seems I recall this happening to another member recently. I don't have the manual in front of me at the moment, but did it call for some lube around the parts that slip together?
    Jun 2016
    Vancouver
    7
    Thanks Texas Splash - Turns out you have to give it a good shove with the palm of your hand and it snaps in place. The 6 way valve fits very snug into the top tank. Once bullied into place you can fit the collar on and tighten the screws.
    Jun 2014
    15,093
    Ahhhh, the old technique. A little extra "persuasion" required.
    Jun 2016
    Vancouver
    7
    Yes and I have regretted using that age old technique many times over years but this time it is exactly what was required. How do you close out a thread as solved on this forum? Or do you?
    Jun 2014
    15,093
    I'll be glad to do it. Thanks, and glad you resolved your issue. Enjoy your weekend.
