Thread: Calimar Titanium/Compupool/CircuPool G Series???
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello All,
    Received a Calimar Titanium edition to replace a Compupool CPX series power supply that died. The paperwork states its a CircuPool G Series Power Pack. Compared to the CPX/CPSC units there is more heatsink surface area, it extends to the sides. It looks like the powersupply/main board are the same in the Calimar Titanium edition and the CPX series but use a different control panel. The changing of the input 115V/230V procedures are the same on the CPX/CPSC and Calimar Titanium editions, and are different on the Circupool RJ-G instruction manual and some of the Circupool RJ series use an external switch.
    Calimar Titanium Edition Manual: https://www.poolsupplyunlimited.com/...1551364159.pdf
    CPX Manual: https://www.poolsupplyunlimited.com/...0143794413.pdf
    CircuPool Manual: http://www.circupool.com/mobile/down...usersguide.pdf
    CircuPool Manual showing flow switch: http://www.discountsaltpool.com/Circ...tor-Manual.pdf
    Invoice showing Circupool G Power Pack from CompuPool.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Calimar Titanium/Compupool/CircuPool G Series???
    I put a call out to see if we can help out with this
    Apr 2011
    Murrieta, CA
    2,360
    It's all good. Lots of conflicting info out there on these units. I used to be a strong supporter/recommend the Compupool units, now not so much. When it works, it works well, when it doesn't, customer support has addressed the issues, but when they don't have the parts and you have to wait for shipment from Australia it takes too long. My CPX is now a Calimar Titanium series due to warrantee coverage. 😀
