Results 1 to 7 of 7
Thread: determining how long to run pump
    Jul 2008
    Bucyrus, Ohio
    108
    I am wondering how to figure out how long it takes a pump to turn the water over completely? Need to figure out how long to run my pump atleat all my water makes it once thru the filter a day.
    Thanks
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: determining how long to run pump
    Try reading Determine Pump Run Time in Pool School.
    mas985's Avatar
    Pleasanton, CA
    11,644
    With your pool size and pump, a turnover is the range of 1.5-2 hours.
    Mark
    Jul 2008
    Bucyrus, Ohio
    108
    Quote Originally Posted by mas985
    going to the site a couple of posters ahead of you it should take 5.3 hrs to completely turn over my pool. could you please let me know where you got your information?
    Overwhelmed
    A Hayward 1 HP above ground pump should be moving around 60 to 80 GPM. Assuming 60 GPM and 5300 gallons gives around 1.5 hours.
    The Pentair web site is designed for in ground pools.
    mas985's Avatar
    Pleasanton, CA
    11,644
    Quote Originally Posted by jshinklin
    The Pentair site has a minimum pool volume of 10k but with that gives a turnover of 2.6 hours so I'm not sure how you got 5.3 hours. 53% (5300/10000) of that value is 1.4 hours but an inground pump will probably pump more water. I used the mid point on a typical above ground Hayward pump which was 60 GPM. Either way the number is close to 1.5 hours.
    Mark
