Thread: Taylor Water Balance Calculator versus Pool Math
    Feb 2016
    McKinney. TX
    42
    Today's readings:
    Cl 2.8
    pH 7.8
    TA 80
    CH 250
    CYA 80
    Salt 3400
    Temp 94
    Pool size 12.000 gallons
    The K-2006 kit comes with a water balance calculator. Entering the above, I get a CSI of 0.35. I would normally add about 20 oz MA to drop pH to about 7.4 and the CSI to -0.05.
    Entering all the above into Pool Math, I get a CSI of -0.07...so I'd do nothing (except bump up the Cl). Why the difference???
    Thanks
    12,000 gallon, in-ground, Lunar Quartz-Bermuda finish. Pentair Intelliflo Pump and Pentair cartridge filer. Polaris 280 pool sweep. Circupool SJ40 SWG.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Taylor Water Balance Calculator versus Pool Math
    Just as there are many theories on different methods of pool care, chlorine, bromine, UV, ozone, mineral, saltwater. There are several different scales and theories for calculating saturation indices in pool water. Some of these include CSI, LSI and Hamilton.
    Here is one discussion, Langelier and Calcite Saturation Indices (LSI and CSI)
    JoyfulNoise's Avatar
    May 2015
    13,201
    The Taylor WaterWheel uses the saturation index (SI) which is a different scale than the CSI.
    Use Pool Math to calculate CSI and follow that scale.
    Matt
    Feb 2016
    McKinney. TX
    42
    Thanks...guess I shall have to Google what Taylor's SI is. I generally use Pool Math as a guide.
    May 2015
    13,201
    Quote Originally Posted by vetman85 View Post
    Very brief intro here -
    https://www.taylortechnologies.com/p...alculators.pdf
    Matt
