Thread: Leak where the valve sits on the filter. New filter. What did I do wrong?
    Aug 2014
    westfield
    60
    What I can think of, is that I lubricated where the o ring meets the valve, but not where the valve sits on the filter. Could that of been my mistake?
    It's on both sides where the clamp is tightened by the screw
    Thx
    smitty195's Avatar
    Feb 2015
    Melbourne, Victoria, Australia.
    58
    Re: Leak where the valve sits on the filter. New filter. What did I do wrong?
    The only thing it can be is the O ring is not seated properly..or it has stretched. how old is the filter and did you check the o ring for cracks in the rubber before replacing the valve.
    intex ultra frame round pool 6831g totally hard plumbed with hayward variable speed pump and jandy cs150 cartridge filter... plus a solar heating roof system with a .75 onga pump and 24" sand filter.
    Aug 2014
    westfield
    60
    Filter and o ring< 18 hours old
    smitty195's Avatar
    Feb 2015
    58
    Wow... i would definitely be checking for cracks in the o ring... just hold the ring in both hands and flex it... if the rubber is dried out you will see the cracks... hope this helps.
