Thread: pump to filter hose blows off
    Sewingmom's Avatar
    Jun 2016
    Woodville/Alabama
    6
    Help, We had a new pump and sand filter installed last year. last week twice the heavy rubber hose from the pump to the filter blew off draining the pool below the skimmer intake. I replaced it and clamped it tighter. 2 days later it blew off again. I assumed I hadn't gotten it down all the way on the pump pipe so I greased it with Vaseline and pushed it sown all the way and clamped it tightly again. Next day it was off. Lots of expensive water wasted. I need to know why it blew off in the first place and what to do. My son told me it had done the same thing last year but he hadn't told me but just shoved it back on and tightened the clamp. The clamp is the slotted metal sort with a screw that one must turn to tighten it. I need all the advice I can get. I do not have great amounts of physical strength as I am 67 years old.
    The pool man I consulted on the phone told me to get all the grease off and put the hose back on and try 2 clamps.
    Belinda\sewingmom
    sewingmom
    chlorine system, sand filter, Hayward pump, 24" round abg, BBB method
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: pump to filter hose blows off
    In the short run, is there any way you can put the hose clamps back on, then wire around the screw part back to something on either end to hold it until a better solution can be found?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    You may need to replace the hose, clean all the vasoline off the fitting on the pump, and get someone with more brute strength to tighten the clamps for you. Also check the fitting on the pump. It should have ridges on it to help grip the hose, and make sure there are no cracks. The best way to resolve the problem would be to have the pool hard plumbed with PVC. You may want to look into that at the end of pool season.
    Love TFP? Become a
    TFP Supporter!
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Use an open end wrench to tighten the hose clamp. A screwdriver rarely provides sufficient torque to secure it. The slot is only to tighten it quickly until you use the wrench.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    May 2015
    Fort Mill, SC
    179
    I really don't get the attraction to hoses and hose clamps, I'm a big fan of PVC and PVC glue. Done correctly, it never comes apart.
    20K gallon vinyl inground pool, Hayward Pro Series sand filter, 1 HP pump, Taylor K-2006
    Sewingmom's Avatar
    Jun 2016
    Woodville/Alabama
    6
    Hmm, It was Installed with 1 clamp and it tightens around a plastic pipe. (Looks like a cheap rig) I am at the mercy of the salesmen and suppliers and installers. It was sold to us last year and installed by the only nearby installer, supplier. We bought the pool, pump, filter and all several years ago when there was a boom in spa sales. The pool has a 25 year warranty. My husband had a brain hemorrhage Jan 2013 and had not yet shut down the pool. The pump froze. The original pump and filter looked much sturdier. The man who sold it to us went out of business. We live in a rural area an I am on my on to get things done. Simple remedies are the best or me.
    sewingmom
