Thread: Spa side switch button, portion missing
    Jul 2016
    Poway, CA
    1
    Our local birds were so excited about me replacing our Jandy spa side switch, they helped themselves to a portion of one of the button coverings. (The small, round, rubber parts with the raised number.) Since the switch is on the side of the spa, I can't think of a way to cover the unit. Is there something that I can replace the missing portion with? Some waterproof caulk, for instance? The unit is only 3 weeks old and the waterproof membrane over the actual button is intact, continuing to work fine. They never touched the one we replaced, of course. Thanks.
    Jun 2014
    15,093
    Re: Spa side switch button, portion missing
    Hello and welcome to TFP! Sorry about the delay getting back to you. I have to admit, I had no idea those switches were so much $$$! I found what appears to be a similar one HERE, but OUCH! $$$ Since your switch is working okay and it appears to be a cosmetic/protective issue, I would recommend contacting Inyopools.com. If you explain to them what happened, they may have an after-market tip to help save you a few bucks and/or to extend the life of that switch. I hope someone can help you. Thanks for visiting us at TFP.
    Mar 2015
    Sugar Land , TX
    424
    Maybe you can velcro a cover over it. Maybe a plastic lid from a disposible container.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    You need to get that sealed up. I would drain the spa a little, to make sure entire switch was out of the water, or pull the button back out of the conduit a few feet so you can work on it on the deck, and blow out real good. Do this on a sunny, preferably hot day to make sure any water that got inside evaporated out. After you let that sit, get the high-temp silicone (orange) and seal it up. I would probably seal the entire button(s) affected to the hard plastic. Might even want to remove the flap on button #2 to make sure you get the water out of that one too.
    Probably the hardest part of the whole repair is making sure you get all the water out of it because once you seal it up, it is in there!
    Compressed air maybe?
    Factory Warranty Station for:
