Results 1 to 8 of 8
Thread: Clear pool but possible algae
    Jun 2016
    Center moriches
    23
    ..My pool is clear, but when I brush the liner a cloudy film gets kicked up, almost like a powder, then it settles again. Any idea if that is normal? Salt pool..DE filter.
    24,000 g salt pool, intellichlor IC60 SWG, L-shaped IGP, Pentair Superflo VS pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Clear pool but possible algae
    Could be dead algae.....got any test results for us?
    Jun 2016
    Center moriches
    23
    My test kit hasn't come yet..all's I have are my strips...FC is 10..CYA is 50..but you know these strips aren't accurate..if it's dead algae, should I power vac out of pool, or can I run through my pool vac filter (not my pool filter)
    Apr 2010
    East Texas
    9,643
    Doesn't matter as long as it gets filtered out!
    Jun 2016
    Center moriches
    23
    Is time of the essence? The sooner the better, or can I do this on Monday?
    Just jammed pack right now
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    As long as the pool passes the Overnight Chlorine Loss Test it is probably OK. That means it is not growing actively.
    Jun 2016
    Center moriches
    23
    I know, but my test kit is coming on the 8th. How can I keep my pool from spiraling out of control in the mean time? My last"pool strip" reading had the FC at 10 & the CYA at 50. Right now my SWG is off bc the chlorine level is high. When should I turn it back on? When the strip reads 5 in the FC level? Thanks for your help?
    DFW, TX
    24,509
    With CYA at 50 keeping your FC between 6 and 20 is safe to swim and will keep algae from getting worse. FC/CYA Chart Also, brushing daily will help.
