Thread: how to start saltwateR?
    Aug 2015
    Boston, MA
    7
    Hello,
    We are 30 days past pebble tech curing time and are supposed to now start salt water .. does anyone know how to make this transition? should i just be adding salt? thanks
    inground gunite 23 shallow end, 18 deep end 40 long pebble tec pool with spa
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: how to start saltwateR?
    Hi Jesse,
    yeah, if your plaster has cured for 30 days, just add the correct amount of salt to the pool for how ever many gallons of water you have. DO NOT turn on the swg yet.
    Let the salt mix in with the water for 24 hours. After the 24 hour mark, go ahead turn on the SWG and start enjoying it.
    Divin Dave,
