Thread: Jandy PDA not controlling Aquapure SWG
    Jun 2016
    N Richland Hills, TX
    1
    Hi,
    I've had an issue within the last couple of weeks where my PDA will no longer control the SWG chlorine production. It still controls the pump and cleaner programs, but when the pump is running, the chlorine production shows 00%.
    This is strange, because I can still choose boost mode on the PDA and get the SWG into boost mode. This is how I've been keeping the pool chlorinated, but it requires me remembering to do it every morning!
    I've cleared the memory on the PDA, reset the control panel at the breaker, replaced the PDA battery - at this point I'm out of ideas. Any help would be appreciated.
    Thanks, and have a happy and safe 4th of July weekend!
    Dan
    12K gal, IG pebble, 2HP Jandy ePump, cartridge filter, Aquapure SWG, Aqualink RS controller, Aqualink PDA, Polaris cleaner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Jandy PDA not controlling Aquapure SWG
    Welcome to TFP
    Sorry no one has been able to help yet, it is a long weekend maybe someone will see it this week and be able to help..
    Sep 2016
    Destin, FL
    4
    I'm having the same issue. I've checked the PDA connection to main board and it looks OK. Did you ever find a solution?
    Ft Lauderdale, Florida
    1,455
    Your best bet is to separate the Aquapure from the controller and make sure the salt system is working correctly by itself. If so, then it may be the communication wires or the PDA/Controller that's causing the problems. Sometimes all it takes is for one of the communication wires to break. These are usually single core wires, rather than stranded. Single core wires can easily break if bent back and forth a few times.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Sep 2016
    Destin, FL
    4
    The sensor communicates with RS6 controller, but the controller doesn't communicate sensor readings to/from the PDA. If I change % from the PDA, it has no affect on the controller. When the system shuts off for the night, the aquapure resets itself to 5% according to controller display so I have to put in service mode and manually increase each morning. Where are the communication wires located and is that something that can be repaired?
    Sep 2017
    Houston TX
    1
    Hi there. I know this is an older thread but I'm having this exact problem and unable to to find the solution. From the console (the Aqualink RS Panel) the aquapure works fine when I place it in service mode. But when in automatic mode, the hand held remote wont turn it on (even though is allows me to set a %). Also, the pool temp and salinity level don't display on the hand held remote but do on the panel display. So I don't think it a sensor, but most likely a data communication issue. No error codes are showing either. Any help would be greatly appreciated.
    Brad
