Results 1 to 14 of 14
Thread: Help my pool has gone green
    Help Am new here my pool just crapped out on me. Was out of town for 5 days to return to a extremely green pool. It was crystal clear when I left. Need an action plan
    This is what it looked like 5 to 10 days ago.
    This is what I found today:
    25000 inground gunite , sand filter with zeobrite sand, 1.5 hp hayward centurion pump, barracuda X7 suction cleaner, 4 deck jets, one aerator, ozone generator.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Help my pool has gone green
    Well, you need to shock your pool... Pool School'sDefeating Algae is the place to start. Can't suggest anything more specific unless you provide some test results.
    --paulr
    BBB "Intermediate Swimmer"
    Jun 2007
    NC
    255
    Quote Originally Posted by AzBlk
    Help Am new here my pool just crapped out on me. Was out of town for 5 days to return to a extremely green pool. It was crystal clear when I left. Need an action plan. This is what it looked like 5 to 10 days ago.
    Before you go any further you need to read Jason's "Turn your swamp into a sparking oasis"... http://www.troublefreepool.com/turni...sis-t4147.html
    When you've read it, please post your water readings. We're glad to help, but can't offer much help without knowing what's going on.
    This is workable!
    Was the pump running while you were gone?
    What test kit are you using to check you water?
    Please put the pool information (size, type, etc.), filter type, pump size, water features, chlorination methods, etc. in your postings (-> control panel, ->profile, ->edit segnature).
    That way we won't keep asking...
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    Thank you very much I read those posts and I hit it hard with shock. I seems the algae is dead/dying but those water is now very cloudy but blue again.
    Round Rock, TX
    529
    Run your filter continuously until it has cleared it up. You may need to backwash, depending on your filter type.
    Add your pool specs to you signature as that will help people give you correct info.
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Jun 2007
    NC
    255
    In addition to running your pump 24x7 you'll need to brush several times a day.
    Please post your water readings...
    By doing that we may be able to help you adjust your water so that you don't come home to a "greenie-meanie" again .
    Triad Region of NC
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You know you are done shocking when:
    You lose less than 1ppm FC overnight;
    Your CC is .5 or less;
    Your water is sparkly-clear.
    Unless those three criteria have been met, you aren't done yet....
    This is workable!
    Signature edited to include pool information. Yes pump was on a 4 hour timer should have been running. We had a bad storm when I was gone and maybe that was part of the problem. I dont have a test kit, take water to pool store
    Thank God for this forum. The pool is getting better but still needs a lot of work.
    24 hours after first shocking:
    48 hours later:
    Still adding shock every 6 hours and taking water to pool store once a day.
    These are the latest test results. Pool is looking better but its just not getting there quick enough.
    FC - 2.5 ppm
    CC - 0.0 ppm
    TC - 2.5 ppm
    CYA - 25 ppm
    pH - 7.6
    Is there anything else I can do besides add shock and keep testing. I need a big bottle of POP.
    30,426
    Keep adding more chlorine. You should not let the chlorine dip below shock value. 2.5ppm is way too low.
    Casey's Avatar
    SW PA
    10,450
    I agree, keep shocking!
    It didn't turn green over night, and it's not gonna clear over night. Crack open the POP, sit back and relax! It'll be beautiful once again!
    Mar 2008
    Los Angeles, Ca
    222
    You really need to look at getting a good test kit. It may seem like a lot of money for the full tftestkit, but it's worth every penny, easily pays for itself with just the frustration it will save you.
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    Butterfly's Avatar
    South Carolina
    10,045
    Ditto to Randy's comments.
    The best investment we made in our pool is the test kit. It has saved us many, many $$ and put us in control of our pool.
    I highly recommend the TF100 from http://www.tftestkits.net. Not only is it one of the two most recommended, it is a better bang for the $$, A-1 service, and duraleigh, the owner, is always around to help with any testing issues.
    Do yourself and your pool a big favor and order one.
    You're done SLAMing when:
